Goldair ghc-803h air cooler. Why is it constantly turning on and off?
No timer is set
Posted by jaqueline jacobs on
Tom Chichester
    Top Expert:
  • Heating & Co... Master
  • 61,336 Answers
The fan is temperature controlled. The controlling device may be defective, leading to erratic cycling.
Posted on Jan 18, 2021
  • jaqueline jacobs
    jaqueline jacobs Jan 19, 2021
    Thank you bit we did manage to get the problem, our tv box remote is working on the aircooler, when we scroll down it turns off and on
  • jaqueline jacobs
    Thank you but this was not the problem our tv box remote worked on the aircooler. When we scroll down it switches on and off
4 Related Answers
Anonymous
  • 3130 Answers
SOURCE: zoom picture
Very little info you gave but go to the screen set up or format menu and switch around to the screen size that works for myou. Or best yet, go back to the store and ask for a little customer education. You see with out the instruction manual in front of me and the set here as well, this is a hard call. Im not at all trying to put you off, just quessing is not going to get you anywhere. Like I said the best thing to do is call customer service listed in the owners manual or go back to the store where you bought it, as maybe there is a problem with it?? Good luck
Posted on Oct 09, 2006
Anonymous
  • 37 Answers
SOURCE: Custom setting
This is a known (albeit uncommon) issue with F100's.  Is the wheel on the top left set to the timer setting? If not it may need to be repaired.
Posted on Oct 23, 2007
Anonymous
SOURCE: Set up Intermatic outdoor timer 7day/7event
I have misplaced and forgot how to set a Model HB65R timer, can you help, thanks, Murray
Posted on Dec 24, 2010
Anonymous
SOURCE: I have an Intermatic 4
You might need new trippers?
Problem is not fully clear.
Can't tell what is new, and what is not working. Add a comment.
You have a new timer with same problem as old timer.
And you have a new control box and switch.
At your new house.
You have RC2343PT air switch, likely with PB913N84 24-hour timer module with manual override knob.
http://waterheatertimer.org/images/Intermatic RC2343PT.jpg
http://waterheatertimer.org/pdf/Intermatic-PB800-PB900-timers.pdf
http://www.poolandspacontrols.com/~/media/Files/PoolAndSpaControls/Products/Instructions/RC2403RT.ashx
The RC2343PT air switch operates a pool-n-spa blower switch.
Pool and spa blower successfully turns on-and-off with circuit breaker.
Did you install a new PB913N84 timer module?
Are both ON-and-OFF trippers present? Are the 107TN222 and 107TN221 on-off trippers worn down and need replacement?
Does the timer dial rotate and keep good time?
What happens when you manually rotate the timer dial clockwise two rotations? Does the blower turn on-and-off?
Have you checked wiring terminals for signs of loose or burned connections?
Add a comment with more information for possible additional help.
Posted on Aug 31, 2011
How to switch on heater for Goldair cooler and heater
The best solution you'll get from books at www.reliable-store.com
These are books containing info on repair, service, troubleshooting, parts info, assemb boats, excavators etc.
Jun 12, 2018 | Cars & Trucks
I lost my manual and dont no how to operate my goldair gac 700w cooler
HOW DO I CLEAN THE TANK FROM THE GOLDAIR AIR COOLER (MODEL GAC-700W)
Dec 01, 2013 | Heating & Cooling
Black Screen
You might have set its 'On Timer and Off Timer' time. If so, the set will only switch ON, after the On timer time set. Try to switch on at different times, and when the set switches on, go to its menu, and set both On Timer and Off Timer to '0:00' and save the settings.
Jun 26, 2013 | iSymphony LED19iH55D 19 TV
Goldair electronic timer manual
1) Copy following links to help identify timer and download possible manual for goldair timer:
http://waterheatertimer.org/Woods-timers-and-manuals.html#13568
http://waterheatertimer.org/UPM-timers-and-manuals.html
http://waterheatertimer.org/How-to-set-timers.html
2) Add a comment and clearly describe timer and timer buttons and what you have discovered using possible manual from link above.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Dec 26, 2012 | Leviton 6124H 24 Hour LCD Programmable...
Resetting outdoor light timer
I would unplug the timer. Change the setting to 6 hours then plug back in.
Dec 08, 2008 | Coleman Cable Outdoor Easy Set Timer #4604
Zoom picture
Oct 08, 2006 | iLO 3200 32 in. LCD Television
Heating & Cooling Logo
13 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Marvin
Marvin
