Question about Refrigerators
It goes through the whole process and dumps water
When a commercial ice machine has is not making ice anymore or makes low amounts of ice, check for the following: Water supply is disconnected See if the water supply valve is turned off or supply hose is disconnected. the Water-float valve and screen are dirty Clean the valve and screen to make ensure proper ice production
Posted on Jan 18, 2021
SOURCE: Ice maker not dumping ice
Make sure the freezer is at least 17 degrees or colder (colder is better). If you have a square cover on the end of the ice maker see if you can pull it off and press on the gear face (don't turn just press). That may clean the electrical contact springs and get it working again. Basically if ya got water, 17 degrees or colder you will get ice. Other than that the ice maker motor module is likely bad (broken gear, etc.). Pretty common.
Posted on Nov 09, 2006
SOURCE: Whirlpool refrigerator ED22TEXHW01 ice maker
Tammi, you first want to check to make sure the water inlet tube to the icemaker is not frozen shut. Next, get yourself a jumper wire about 4 inches long with the ends stripped exposing the wire on each end. Pull off the ice maker cover, it will pull right off. Now you are looking at the module. On the module, left side, you will see two test points marked V and L. Insert one end of the jumper wire into V and the other marked L. You are now sending 120 volts to the water valve and water should fill the ice maker providing the inlet tube is not frozen over. If it doesn't fill, you either have a bad water valve or module itself. Also check to see if the clips that hold the center gear on the module are not broken. Catriver..post back.
Posted on Mar 22, 2007
My lady friend has the same problem with her ice maker. The problem is, the ice tray is broken on the end. I took her ice maker out and found out it was broken. Its going to be hard finding a replacement since they don't make parts anymore.
Good Luck !!!
Posted on Dec 02, 2008
SOURCE: Samsung side by side RS2556BB. Ice maker is not dumping ice out.
you need to remplace your control board
is not suppling power to the ice maker heater element you will find the control boar nex to the wather valve
Posted on Jun 07, 2009
SOURCE: Bellini ice maker model FS-Z03.
ice full light stays on even when there is no ice. and the unit will not run
Posted on Jun 17, 2011
Jul 07, 2014 | Hoshizaki Freezer Commercial Ice Machines...
May 20, 2012 | GE GSS25SGMBS Side by Side Refrigerator
You
have two sides to the water control valve. One side is for the water coming from
fountain and the second side is to refill your ice maker after each cycle of
dumping ice into the ice bin. The freezer should be a 5 degrees or below for
the ice maker to function properly. If the ice maker is empty then fill with
tap water up to top edge of the ice maker and allow to freeze. If after the
water freezes and dumps the ice into the ice bin the ice maker does not refill
I would recommend replacing part=> 67006009 Dual Water Control
Valve
or here=> 67006009 Dual Water Control Valve
If the ice maker has old ice inside and does not want to dump itself it will be considered defective and the ice maker core moduel will need be replaced=> W10190972 Ice Maker Assembly
Whirlpool Ice Maker Troubleshooting
I will be here
should you have any questions, Thank You, Sea Breeze
Please Rate this Solution
Feb 08, 2012 | Refrigerators
Aug 29, 2011 | Hoshizaki Freezer Commercial Ice Machines...
May 13, 2010 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Dec 04, 2009 | Whirlpool ED2FHEXN Side by Side...
Sep 07, 2009 | Maytag MSD2454G Side by Side Refrigerator
Aug 15, 2009 | Refrigerators
Jul 25, 2008 | Frigidaire FRS3R5EMB Side by Side...
Mar 03, 2021 | Refrigerators
Mar 02, 2021 | GE Refrigerators
13 people viewed this question
