Question about Electrical Supplies
Powerhouse 2100 pri inverter/generator. Why is no green run light on when running?
Also the remote start will not operate.
Posted by Terry on
5 Related Answers
nitrospawn
Ibe Chukwudi
  • 290 Answers
SOURCE: Heart interface 30 marine quit charging
the charge fuse may have broken or the charger is bad
Posted on Feb 26, 2010
ftw1952
frank thomas wilson
  • 10319 Answers
SOURCE: how can i get electricity inside my slide in truck camper
carry an extra altenator just in case for your truck
Posted on Mar 12, 2010
kel1guy2002
Kelly
  • 3740 Answers
SOURCE: generac generator on auto runs
Hi and welcome to FixYa I am Kelly. Your red LED is telling you that it was 1. overloaded. 2. has low voltage 3. overheated or 4. short in the powered circuit.
OVERLOAD LED (red): Lights up if the generator experiences
a load greater than the rated output, low voltage, overheats or
the powered circuit experiences a short. The output is stopped
even though the engine keeps running.
I do not know which of the 4 conditions caused your red light. If you have the read light with no load I would suspect low voltage from the generator / inverter. If it overheated you will also get the Red LED with no load.
Thanks for choosing FixYa.
Kelly
Posted on Aug 30, 2010
Anonymous
  • 90 Answers
SOURCE: we have a Kawasaki GE5000
there are several componants that need to be checked. you will need to know how to use a volt ohm meter to check the generating parts. there should be a rectifier and capacitor to check. then you need to check the field for a beak in the wire or if it is grounded. then you need to check the armature for a break in the wire. some armatures have diodes in the wiring and those need to be checked. then you need to check the outlet itself and the breaker. there are a lot of things to check.
Posted on Sep 01, 2010
Anonymous
SOURCE: my daikin inverter does not turn on. when i press
I am having the same problem! It works when I put it on fan mode but none of the modes that require a specific temperature work. It opens the whole way and then closes again!
Posted on Dec 19, 2010
Sylvania lc320sl1
in this television .if you see the digital television .its the inverter board. try a probe pull off the small cable of inverter board .and try to turn on the tv .if the light stay green the inverter is out. thanks
Dec 10, 2013 | Televison & Video
The output(w) is indicating o.oo and it's indicator light is red .I only have a couple of floor model fans plugged. Should it be showing something and should the light be green?
inverters run on a square voltage unlike normal 110 runs on a round voltage, the only 2 things that won't run on the inverter is fans and electric blankets
Jul 22, 2011 | Cobra 2500w Power Inverter
Split system turns off after 35 minutes. Vanes close but operation green light blinks four times. By pressing on/off switch on remote - green light stops blinking. Press on/off switch again, system starts...
Out door compressor getting over heated. Check freon pressure. May be short of gas. If fan motor less rpm, replace capacitor. If condenser dust blocked,m clean it.
Jan 19, 2011 | Heating & Cooling
My fujitsu inverter asta12jcc outside fan is not working. On the inside unit the operation light is on for a few seconds than the green timer light flashes every few seconds. but the fan inside is running.
Communication error between indoor to out door.Comms Error, check your wiring, remove external pumps. Split/Multi - check volts from terminal N to 3 = 0 - 65 Vdc, Multi V - 4 Vdc terminals 3 and 4
Jan 02, 2011 | Heating & Cooling
I have a Fujitsu inverter split system,(ASTA18LCC) which the power was removed for a while. Now when you start it up on any mode the red operation light is on briefely, then the green timer light flashers...
To work out what the error code ispress the orange start/stop button on the remote controller so unit operationis stopped.
Then press and hold "energy save" and "zone control" buttonsimultaneously for at least five seconds, the error code will be along thelines of En:nn where the "En:" is the error code and the":nn" indicates the indoor unit address if there are multiple indoorunits connected to the one controller. If the upper vertical bar on the capitalE is missing so it looks maybe like a 2 or something don't worry for somereasons they just do that
Some common error codes are:
E0 Communication error between indoor unit and wired remote control, check ifthere is 12VDC between terminal 1 + 3 at remote control and 8-9VDC pulsatingbetween terminal 2 + 3. If DC volts out of Indoor pcb is below about 11.6VDC itwill cause this error, the problem is normally dry capacitors in the 12 VDCpower supply section. This model has two power supply sections on indoor pcb.
E1 Communication error between indoor unit and outdoor unit,
EF Discharge temperature abnormal
Is it helpful?
Dec 27, 2010 | Fujitsu 24C1 Air Conditioner
I have a 2003 Dynasty and we're having an electrical problem that has just about puzzled everyone I've spoken with ! It all began over 2 years ago when I started the generator and the engine , to return...
Sounds to me like a problem arises when auxiliary batteries are getting charge from more than one source at a time. When unit is plugged in, or generator running, that supplies one source of charge to batteries, when you start the engine, that supplies another. perhaps it's sensing an overcharge condition when this happens, and is warning you that when you put too much charge at once to deep cycle batteries, you may boil them, and cause premature failure. Personally, if it were me, I'd disconnect the charge line from the alternator, and put it on a switch, that I could shut off, and on as needed, and be done with it. When generator running, shut it off. Double check operation of your battery isolator as well. If 2 strong sources start charging those batteries too fast, that's not good. I'd also think about, or discuss with an electronics guy about adding a diode to charge line from inverter/converter, to stop any possible feedback from alternator when engine running. That said, It shouldn't take more than 1/2 hr, to find charge line from alternator to batteries, and put a switch in a convenient spot in unit, to connect and disconnect as needed. Cheap and easy solution.
Jan 08, 2010 | Xantrex Technology 806-1800 Prosine...
Green power light on no sound or picture cycles
MAYBE INVERTER BOARD BAD..
INVERTER BOARD IS A PART OF THE LCD PANEL UNIT
Sep 28, 2009 | Sharp LC-32SH12U TV
2nd season with 400 watt vehicle 1024 inverter. The
Restating the question - 400 watt inverter is turned on and running with the vehicle turned off.
After starting vehicle the red light of the inverter is on with no power output from the inverter.
If you turn the inverter off then on inverter operates normally.
Solution - this is normal operation - my inverter does the same thing. When you start the vehicle
it draws a lot of current from the vehicle battery which causes a drop in battery voltage. Most inverters have a low voltage input safety and will fault the device.'
If the problem is turn on inverter then the red light starts flashing... I am thinking you
have the same problem as the one I replaced - it broke... I am sure some capicator
or other component in the circuit failed... My solution was to purchase a new one...
Mar 03, 2009 | Inverter Vector 400-Watt Power
Samsung aircon turns in 5 sec. lights green/yellow flashing
check capacitor on outside unit,or gas is leaking.
try to reset(small black button in inside unit under the cover)
Feb 11, 2009 | Samsung Heating & Cooling
Flashing lights on system
Maybe the unit is on test run, try to push the test run button of remote control pointing the remote to the unit receiver.6d9792c.jpg
Jan 07, 2008 | Heating & Cooling
Electrical Supplies Logo
Top Electrical Supplies Experts
Marvin
Marvin
john h
Are you an Electrical Supply Expert? Answer questions, earn points and help others
