Question about Kenmore Dryers
SOURCE: acer aspire 360-2682 notebook
better no to disassemle laptops by your own refer to a qualifying service proffesional
Posted on Dec 03, 2007
SOURCE: Motor runs but beaters do not turn.
I challenge you to do-it-yourself...you can do it. Just be careful when removing it apart. I advise you to take a video or get some snap shots while you are at it. This way, if some springs snaps out, I assume that you took a picture of it already.
Usually those plastic gears are the problem. Goodluck!
Posted on Jan 13, 2009
SOURCE: Kenmore Elite HE3 Dryer clothes not dry after cycle
it sounds like a clog in vent.if yours vents up thru roof you may need to have a chimney sweep come out and sweep vent.check and make sure the vent hose is net kinked or full of lint.
Posted on Mar 06, 2009
SOURCE: How do you disassembly the JBL PSW_D110?
what i did was i stuck my hand in the port, screw driver in hand, used the blunt end of the screwdriver put it in the indent on the magnet on the back of the sub, positioned it so that the end of the screw driver was stickin out and smacked it with a hammer and it popped out, make sure u take the screws out of the front of the sub, and then take the insulation out of the box and do the same thing to th eboard just do it on theblack part of the amp not on the board
Posted on Mar 29, 2009
It normally takes about 45 minutes for a dryer to dry a full load. If your dryer is taking more than an hour, check these.
Vent
Heating element
Internal ductwork
Cycling thermostat
Vent
Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance.
Heating element
Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace it.
Internal ductwork
Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum, contact a qualified appliance repair technician.
Cycling thermostat
Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork with two screws.
Posted on May 28, 2009
Apr 30, 2018 | Kenmore Dryers
Jul 04, 2016 | Kenmore Dryers
Jan 02, 2014 | Dryers
Dec 28, 2010 | Kenmore Elite HE3 Steam 8674 Dryer
Jun 11, 2010 | Kenmore Elite HE3 Steam 8674 Dryer
May 18, 2010 | Kenmore Elite HE3 Steam 8674 Dryer
Mar 09, 2010 | Kenmore Elite Oasis 7808 Gas Dryer
Oct 13, 2009 | Kenmore Elite HE3 Steam 8674 Dryer
Jun 16, 2009 | Kenmore Elite HE3 Steam 8674 Dryer
Apr 10, 2009 | Kenmore Elite HE3 Steam 8674 Dryer
Jan 20, 2021 | Kenmore Dryers
16 people viewed this question
