Kitchen Appliances - Others Logo
Question about DeLonghi Kitchen Appliances - Others
Fryer. Why does it turn on, then 3 or 4 seconds later turn off and display "ERR"?
Brand new. have set it up when i plug it in the red and green lights come on the temp setting is 320 degrees - it stays on for 3 or 4 seconds then the display says "ERR"
Posted by Michael Teixeira on
David Spradling
    Top Expert:
  • DeLonghi Master
  • 12,586 Answers
Bad power supply or heating element
Posted on Feb 28, 2021
5 Related Answers
Anonymous
  • 640 Answers
SOURCE: problems with fryer
your problem is the thermostat is bad.the reason it shuts down is that it trips the hi limit.the hi limit is a saftey device that shuts the system down so the oil doesnt get too hot and catch on fire.remove all the oil from the tank and you should see 2 skinny metal bulbs one is the hi limit bulb the other is the t-stat bulb,make sure they are secured to the bracket.if the t-stat bulb isnt you will also have this issue,simply reattach it.let me know.
Posted on Nov 11, 2007
Anonymous
SOURCE: delonghi cf210 when setting temp it dosnt give any heay
just bought one.It looks like the thermostat has problem. Set at 78 F, it runs forever and the room temp is 72F. Set at 79F, it runs, room temp shows 73 F, sometimes 75F or 77F. The Ac is on then off every 5 minutes even the desired temp (is set) reached. Lousy machine.
Posted on Aug 11, 2008
Anonymous
  • 1077 Answers
SOURCE: set up new tv - doesn't work
Warranty time. The TV most likely went into protection mode because a part went bad inside.
I would take it back to the store and exchange it for a new one. 90 day warranty policy.
Have them test the new one to make sure it works so you don't have to waste another trip.
Good Luck
Posted on Feb 09, 2009
Pamcredible
  • 8 Answers
SOURCE: STARTS UP VOLUME COMES ON 5 SECONDS LATER NOTHING
Try this... it worked for me after 3 years of dead TV.http://www.fixya.com/support/t129700-green_flashes_tv_turns_off
Posted on Mar 04, 2009
Anonymous
  • 3600 Answers
SOURCE: temp will not set above 32 degrees but will go
You may have a thermsotat problem if you get it to cool that low it will cause the condensor to freeze and will stop it from working.
Posted on Jun 05, 2010
Err code displayed and fails start
Turn the programme selector dial to the required programme.
The selector dial can be turned either clockwise
or counter-clockwise. The green pilot light of the button
9 starts flashing: the appliance is now switched on.
If you turn the programme selector dial to another programme
when the appliance is working, the red pilot light
of the button 9 will flash 3 times and the message Err is displayed to indicate a wrong selection.
The appliance will not perform the new selected programme.
• To switch the appliance off, turn the programme selector
dial to the position .
• To cancel or change a running programme, switch the
appliance off by turning the programme selector dial to the
position
. Select the new programme by turning the selector
to the desired programme. Start the new programme
by pressing the button 9 again. The water in the tub will be
not emptied out.
Dado
Replaced bulb in kdf-50e2000- when powered on green light flash 3 times & fan engages, 2 seconds later fan quits and i get a 3 red light blinks
impossible to actually see if lever is Fully engaged---with door off try to engage with a match stick or something not metal--see if set comes on that way.
1helpful
I turn on the power and before I can set the temperature I get a flashing "err" message and can't do anything.
You are not alone. We have the same problem. Unit worked fine for 2-3 years. We still have the manual. This is not a user error- we know how to use it. The sensor switch is fine- it would not power on without that working ok.
The red power light comes on, and when we turn it ON it says "200" for about 2-3 seconds... then "Err". Nothing is possible after that, the unit has to be powered off.
We can push Temp Mode and start setting the temp higher but after 2 seconds it just goes to Err. It does not matter what buttons you push- you don't have to push anything at all and it says "Err". Reset button does nothing- this is not a heat temp overload issue. This unit worked at Thanksgiving, and then not at Christmas! We tried powering it on 10-20 times... nothing. Then the next day as we were about to put the turkey in the oven I tried the fryer again... and presto it worked fine!!! Now today it does not work again. Tried it 10 times, no go. Unit was stored in pantry (in house) so it is not a cold/warmup issue. I think it is something messed up in the electronics- a weak solder joint, a bad chip, who knows. It's like the unit fails a "power on self test". Unfortunately, I do not have a solution yet. Don't want to buy another Masterbuilt for sure... only use this 1-2 times a year. Will share if I find anything.
1helpful
I own a Samsung HL-R5067W 50'' DLP. Set is about 3 years old. Recently I heard a loud pop while viewing, picture distorted, but never went blank. I turned set off. When turned on again a loud whining noise...
Check your color wheel. There is a DIY guide for replacing the color wheel. Mine did the same thing yours is and my color wheel was all busted up. Unfortunately after replacing the color wheel my set continues to do the same thing, but this could mean I need to replace the ballast as well.
No picture and no sound
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Error message
I don't know if this is the true answer or just works with ours, but if I hold the on button (for heating) and the program button together in a couple seconds it stops blinking and resets to the temperature mode. When that hasn't worked, it's also worked to hit the rest button in the back first and hold for a couple seconds and then hit the two buttons mentioned above together. However, each time I get the ERR message it gets harder and harder to reset. I would love for someone else to respond for the actual "fix" for this as it's looking to be the actual computer part of the thermastat to us and I'm wondering if it's worth fixing or shopping for a new fryer is needed for price. But, this has gotten us through for now to be able to fry again.
3answers
Rival 3-L Cool Touch Deep Fryer
Hi, Its very possible that you have the wrong power to your fryer. I noticed that you said that you tried to plug it in. If it does not seem to fit or if you had to bend anything on the plug to make it fit you need to have an electrician check to make sure you have the correct power to the fryer. The wall outlet will have the power information printed on it. The manual will give you the power requirements. It the plug fits ok, check your breaker for that outlet. Good Luck. If this solution does not rate an (Almost There) Please do not rate.
Thank You,
kstfas
Top DeLonghi Kitchen Appliances - Others Experts
Oloyede Monsuru
Paul Bade
john h
Are you a DeLonghi Kitchen Appliances - Other Expert? Answer questions, earn points and help others
