Technics sh-eh750. Why aren't bass speakers working?
Posted by Steve on
5 Related Answers
Anonymous
SOURCE: Technics SH-AC300 Connection to Power Amp & Pre-Amp
Hi!
The problem is, that your SH-AC300 needs an amp with 5.1 input (but no decoder). For this purpose technics delivered SA-AX710.
So if you'd like to use your current equipment it would be impossible.
The only option is for you to buy 2 more Power Amps (SE-A900S), so that each of 3 amps would take care for one part of music. (one for FL, FR; one for RL, RR; and one for sub and center).
Another option is for you to buy SA-AX710. Then all the problems would be solved with it.
Posted on Feb 24, 2008
Anonymous
  • 232 Answers
SOURCE: Technics SH-8017 Equalizer
use youe tape out signal into the eq's main input and the eq'sout back into the record side of ur tape source.
Posted on Aug 09, 2008
Benimur
Louie Role
  • 6966 Answers
SOURCE: cd keeps jumping on technics
A couple of things you could try:
  • insert a sponge/foam between the bottom of the EH750 and the shelf/table;
  • insert a sponge/foam between the bottom of the speakers and the shelf/table;
  • relocate the speaker;
  • lower the bass;
  • clean the laser lens/eye.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Sep 03, 2008
Anonymous
SOURCE: TECHNICS SC-EH750-CD KEEPS SKIPPING
Sorry , not worth the hassle , bin it and get a better system second hand for around £25
Posted on Jan 26, 2009
Anonymous
SOURCE: technics tuner amplifier sa-eh750
I want to change the language on technics hi fi sa/eh750 to english
Posted on Jun 01, 2010
My subwoofer has stopped working on my technics Sa-eh750 other speakers working fine
Have you checked the fuses, that happens, also double check your wires and ground.
Jul 06, 2015 | Technics Audio Players & Recorders
Technics sl eh750
if your device is on top of a speaker cabinet with all that this may causing intermittent and more when you turn up the volume, change the speakers elsewhere if still the problem may be the rotation or displacement engines and finally the lasser .
Sep 07, 2013 | Audio Players & Recorders
I need a manual for a SA EH750 stereo system
You can download the service manual from here:
http://elektrotanya.com/technics_sa-eh750.pdf/download.html
Please wait until the page is appeared fully then click on this place:
Get Manual
Not logged in
Only 2 downloads
allowed a day
and the downloading will begin.
Thanks.
gylacz
Jul 15, 2011 | Technics Audio Players & Recorders
I have got the technics SH-EH550 UNIT, but i want to utilise the suround sound functions of the SH-EH750 unit on my system. is it just a case of unplug the EH550 unit and replace that with the EH750 unit...
As you stated technics SH-EH550 UNIT can be replaced with SH-EH750 unit ,
Since this unit has the main power Amplifier with suround sound functions in it,you do not need the other units unless you do not plan to use..
Hope this helps!..if more help requires pls let me know.
Jul 07, 2011 | Audio Players & Recorders
Technics tuner amplifier sa-eh750 makes crunching noise and f61 comes up on desplay
Jan 30, 2010 | Technics SA-EX500 Receiver
Cd keeps jumping on technics eh750 system
  • lower the bass;
Sep 03, 2008 | Technics Audio Players & Recorders
Hi!
Jan 15, 2008 | Technics SA-DX950 Receiver
GETTING BETTER SOUND QUALITY
An equaliser is, put simply, a more complex tone control, giving you the ability to cut or boost more specific frequencies than a tone knob, or bass & treble controls.
It comes in handy for tweaking the sound from your hi-fi to just the way you like it. But beware, as it can make your hi-fi produce sounds that are so bass or treble heavy, that you can damage your speakers if you're not careful.
Adding another compnent into the chain (like a graphic EQ) can add a little background noise but this Technics EQ is a pretty quiet one & you probably won't notice the noise apart from when there's no music playing & you've got the amp turned up high.
Jan 10, 2008 | Technics SH-GE70 Home Equalizer
replace travers assy ,because spindle motor is faulty. If you can get spindle only it will be chiper solution for you.
Nov 10, 2007 | Technics SC-EH780 CD Shelf System
13 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
