Question about Sony Televison & Video
VCR starts playback but recorder thinks it is still rewinding. This also occurs with Sony digital camcorder
SOURCE: Sony Handycam CCD-TRV37 8mm Analog... 2 Problems, maybe more unknown at this time:
This does require disassembly to remedy the problem. There are various possible fixes. The most prevelant I have seen is cold solder connections of the board connector for the fpc cable from the top operation switch block ass'y. All you need is someone who can handle this task, like a professional. The controls that you are experiencing problems with are all linked with one cable and connector. One bad solder joint can cause serveral operation faults. Good Luck, magic seadog
Posted on Aug 19, 2007
SOURCE: Sony VCR rewind and counter problem
The belts are slipping. Every 5 years is about right for replacing them all.
Posted on Jan 24, 2008
SOURCE: Even after using head cleaner, no playback
SOUNDS LIKE YOUR MAIN BOARD IS GOING OUT. NEED TO SEND IN FOR REPAIR
Posted on Mar 02, 2008
SOURCE: how do i record on the vcr
do you hve anything going into either the cable in or the rca (red white yellow)?
if you do then make sure the correct input is selected
Posted on Jan 19, 2010
SOURCE: rewind or fast forward
Try cleaning the pinch roller. A cotton bud dipped in methylated spirits should work, you may need several. Play a tape through to clean off the methanol residue. Avoid touching any semionductors !
If this doesn't work, you've just a tired motor.
Posted on Nov 26, 2013
Dec 01, 2013 | Toshiba DVR620 DVD Recorder/VCR
Aug 26, 2008 | Toshiba D-VR4 DVD Recorder/VCR
Mar 23, 2008 | Panasonic Palmcorder PV-DV103 Mini DV...
Jan 29, 2013 | GE lectric Slimline 1Way VHS Rewinder...
Mar 08, 2010 | Sony Televison & Video
Jul 23, 2009 | Sylvania 6240VE VHS/S-VHS playback VCR
Jun 27, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Mar 31, 2008 | Toshiba MW24FP1 24 in. TV/VCR/DVD Combo
Feb 17, 2008 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
Jan 24, 2008 | Televison & Video
Feb 08, 2021 | Sony Televison & Video
15 people viewed this question
