Question about Sylvania Televison & Video
Stuck on auto search for 3 days
SOURCE: My Sylvania 32" Tv Model #SRT2232S won't turn
Hello
There is a fuse inside the power supply bard of your sylvania TV. Check whether it has blown out. If bllown out, replace it with same type bothe in size and amperage. If the newly inserted fuse also blow up as soon as you switch on the set, make sure that the power supply section has some short circuit in it, and should be cheked well. OK.
Posted on Sep 28, 2011
SOURCE: what is rca remote code for sylvania model
Hello
Four digit codes for Sylvania TV with RCA RCR 311W remote control are:
1003, 1004, 1014, 1046, 1051, 1060, 1061, 1062, 1066, 1067, 1072, 1073, 1074, 1075, 1076, 1077, 1078, 1082, 1150, 1151, 1165, 1192, 1199, 1206
Five digit codes for Sylvania TV with RCA RCR4373N remote control are:
11864, 10054, 10030, 10171, 10096, 11271, 11314, 11394, 11963
OK.
Posted on Sep 29, 2011
SOURCE: I have a Sylvania TV, Model #SRT2232S that
Hello
The LOT [Line Output Transformer] of your TV. It should be replace with same type and number. Actually this is a skilled work. You have to unsoder this component out from the circuit board, and to resolder the new one in place. Have to adjust the perfect screen and focus voltage. Screen and focus voltage controls can be seen on it. This component can be bought from most of the electronic spare part shops at your tow. The number printed on it is important and should be noted. The sample picture of that component is attached here. This component also known as Flyback transformer. OK.
Posted on Oct 03, 2011
SOURCE: The front panel on my SRT2232S Sylvania TV has
This can be due to moisture build up or dirt accumulating with a static charge to induce voltage and so change the customer control panel switchings.
You can try with a good cleaning of the board and panels. Make sure to dry if moisture is seen. Also check for static conducion of high voltage to the control panel that can induce the inputs to work erratic.
if not check the processor section- processor damage- and the board for a possible weakness.
Posted on Oct 10, 2011
Sep 04, 2013 | Sylvania SRT2232S 32" TV
Oct 09, 2011 | Sylvania SRT2232S 32" TV
Oct 01, 2011 | Sylvania SRT2232S 32" TV
Sep 29, 2011 | Sylvania SRT2232S 32" TV
Sep 28, 2011 | Sylvania SRT2232S 32" TV
Sep 15, 2011 | Sylvania SRT2232S 32" TV
Mar 06, 2010 | Sylvania SRT2232S 32" TV
Nov 18, 2009 | Sylvania SRT2232S 32" TV
Nov 27, 2008 | Sylvania SRT2232S 32" TV
Aug 18, 2008 | Sylvania SRT2232S 32" TV
16 people viewed this question
