Question about GE Microwave Ovens
Model JVM6172DK2WW. How can I unlock?
Tried various ways
Posted by Marge Zoetewey on
What is the wattage output of my GE Spacemaker Microwave model JVM1850SH02
The JVM1850SH microwave has a maximum power output of 1100W.
I hope this helps.
(The final two digits are not critical for the microwave's specifications.)
Mar 06, 2015 | GE Microwave Ovens
How do we change the bulb on this model?
Sorry to read about your problem, I hope this helps you out.
this model has 2 different ways depending from which factory it was built at...
if is has plastic cover..it will just snap out... or it may have metal cover with screw on it, on the outside of the unit..
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 23, 2010 | GE JES1384SF Microwave Oven
I held CANCEL key too long and now the microwave is Locked. How do I unlock it?
Press and hold the Clear/Off button for about 3 seconds again. This toggles the Child Lock.
I hope this helps.
(I used the model given above to check if the toggle command was the same or different from the lock command. If your microwave is a different model, try pressing the CANCEL button for about 3 seconds.)
Sep 14, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
My control panel has locked and I can't unlock it.
If this is a GE Spacemaker model, you can lock or unlock the controls of the oven by pressing and holding the CLEAR/OFF button for 3 to 5 seconds. If this is not a GE Spacemaker, please post back with your correct MODEL NUMBER. I hope this information helps you.
Jun 24, 2010 | GE Profile Spacemaker Over-the-Range...
How do I unlock the control panel
If this is a GE Advantium series microwave, the control panel can be locked to prevent children from manipulating the controls. To lock or unlock, press and hold the CLEAR/OFF button for 5 seconds. These instructions are included on page 36 of the owner's manual listed here:
http://www.managemylife.com/mmh/owner_manuals/14895/GE-Built-In-Microwave-Oven-L0902200?brand_name_search=+GE+Advantium+120
If you have questions, please post back and let me know. Please include your MODEL NUMBER if diffrent form the model you posted this question under. I hope this helps you.
May 20, 2010 | GE Advantium 120 Convection/Microwave Oven
Can't figure out how the defrost cycle works... can't get manual online.
All microwave ovens are not designed the same and have different features, the owner's manual is still your best bet in determining how to operate your oven. In addition, you did not include a MODEL NUMBER. All GE microwave are not the same and have different features based on model number.
Have you tried managemylife.com or geappliances.com? Both websites offer an extensive list of owner's and installation manuals. Use your model number for your search criteria.
If you still require assistance, please poswt back with your model number so I can attempt to provide you with better assistance. I hope this help you.
Jan 01, 2010 | General Electric Microwave Oven
My problem is "how do I turn off the demo mode on a GE Advantium 120 Microwave/Oven Combo?
Press OFF 5 times to exit store demo mode.
There are different ways for each unit.... please reply with the model # if that does not work for you.
Thanks for using FixYa - a Very Helpful Rating is appreciated for answering your FREE question.
Aug 15, 2009 | GE Advantium 120 Convection/Microwave Oven
Sensor error
I had the same exact thing happen...I put in some popcorn, it wouldn't pop. The screen said "sensor error". I tried heating water, a piece of chicken...nothing would heat. I unplugged it, plugged it back in...nothing. The manual says to close the door and hit the clear/cancel button. I could have sworn I had done that, but my wife simply hit the clear button and it started working again good as new. Hope yours does the same. : ))
Jun 11, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Microwave DEMO MODE
I just bought a condo with a GE Spacemaker Mod# JVM1860SD
that was stuck in demo mode. (This mod# has been replaced by the JVM1870*** series)
I called GE twice in two days, and finally got someone who had the solution (and it worked):
  1. Unplug the unit for at least 30 seconds
  2. Plug the unit back in DO NOT SET THE CLOCK
  3. While the unit is still "booting up" and the display screen is lit with gibberish, HOLD THE POWER LEVEL AND THE ZERO BUTTON for at least 5 seconds.
  4. After 5 seconds, the screen will display "demo mode off"
It messed me up at first because the power level and zero pads don't beep when the unit is booting up... but it worked.
- Again, this is for the GE Spacemaker 1860-1870 series models only - The women who gave me instructions said she had different demo mode unlock methods for the 1400, 3670, 2070 etc... so call GE if you have a different model.
P.S. my model looks like this - the keypad setup is key http://products.geappliances.com/ApplProducts/Dispatcher?REQUEST=SPECPAGE&SKU=JVM1870SK&SITEID=GEA
Mar 01, 2007 | GE Advantium SCA2000B Microwave Oven
Microwave Ovens Logo
19 people viewed this question
Top GE Microwave Ovens Experts
gbob59
randymanfive
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
