Installed new pump. Runs continuously
SOURCE: dishwasher trips the house mains
It sounds to me like you have got water in the Main wash pump, you need to turn of at the mains and put a meter across one of the main tags on the pump and the the other on the pump body, if you get a reading on the meter theres your problem. The only othere thing would be the heater which you can test in the same way.
Posted on Oct 21, 2007
SOURCE: bosch dishwaser
Hi francoisj
There might be water in the bottom pan under the dish washer. first turn off the power, then take the kick plate off and you should be able to feel if there is water in there. If there is remove all of it. you can do this one of 2 ways useing paper towel or my pulling out the dishwasher and tipping it 45 degrees. i recomend trying papertowel first and that should get you going again. hope this helps
brent
Posted on Sep 29, 2008
SOURCE: installed new fuel pump assymbly. car starts fine
Wire connection on pump is poor or incorrect.
Posted on Aug 27, 2009
SOURCE: GE WBVH6240 Front load washer. Pump running while empty
you would need to go into the fault codes and read them. the tech sheet should be under the lid or in the kick panel
Posted on Feb 07, 2010
SOURCE: ASKP 3110 - drain pump continuously running
If water gets onto the pan under the dishwasher, there is a styrofoam float that rises and hits a microswitch that causes the dishwasher to drain constantly so that you don't get a flood in your kitchen. Mine has done this when I splashed out water from a bowl that had overturned during the wash and was full of water and when I had some water deposits built up on the door seal that let water through. Sometimes the foat will hang up and I have to wiggle it around to get it to fall back down.
Posted on Dec 27, 2010
May 06, 2016 | Fisher Washing Machines
Mar 25, 2015 | Fisher and Paykel Washing Machines
Oct 11, 2014 | AEG Dishwashers
Mar 15, 2013 | Fisher and Paykel Dishwashers
Jul 15, 2012 | Fisher and Paykel Washing Machines
Apr 21, 2010 | Saniflo & Saniplus& Macerator Pump
Oct 01, 2009 | Frigidaire Dishwashers
Sep 12, 2008 | Washing Machines
Oct 20, 2007 | Hotpoint 24 in. FDW60 Free-standing...
13 people viewed this question
