Question about Hoover Vacuums
SOURCE: Problems with the Hoover Steam vac Heated carpet cleaner
This happens when the filter on the inside of the lid for the dirty water tank is pushed all of the way up. You need to leave a 1/4 in. gap from the top to the top of the filter.
Posted on Jan 10, 2008
SOURCE: Hoover z400 clogged
There should be a bottom plate covering the brush roll that you can remove, if you can't dig out the what is in there, try using your hose and suck it out from the bottom, maybe you will be able to get it out.
Posted on Mar 06, 2008
SOURCE: Water leaking out bottom with hose attached
The water hose plugs into the solution valve-pressure on the side of the noozle(bottom). There may be a water line that has come loose there, you will have to take the top off to get to it.
Posted on Apr 20, 2008
SOURCE: My Hoover SteamVac Max Extract 77's dirty water
There are several possibilities for low pick up. The most common problem is that the lid is not correctly seated on the recovery (lower) tank. It is also possible that the rubber seal on the motor standpipe is out of place. The round tube on the bottom of the tank sits against the seal. Remove the tank and look for a large rubber ring on top of a plastic pipe. A less common issue is damage to the rug nozzle because the screws holding it against the carpet have been broken loose by dropping the shampooer on it's nose.
Posted on Jan 22, 2011
SOURCE: i cant get the brushes
Remove the brush assembly and insert a flat screwdriver into the square hole and be sure it turns. If it is seized up, the turbine assembly will require replacement. If it turns, be sure the brush control is set to the brush position and the filter is clean. The filter may be on top behind a clear plastic cap, or underneath in red plastic holder depending on the model. The brush will also not turn unless the lower tank is in place, and the handle released and tilted back.
Posted on Jan 28, 2011
Jan 02, 2018 | Hoover Vacuums
Feb 02, 2015 | Hoover SteamVac Carpet/Upholstery Deep...
Jan 20, 2013 | Hoover MaxExtract Deep Cleaner
Aug 08, 2011 | Hoover SteamVac F7411-900 Upright Vacuum
Jan 14, 2011 | Hoover SteamVac F5914-900 SpinScrub...
Dec 04, 2009 | Hoover F6212-900 / F6215-900 SteamVac...
Oct 03, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Apr 15, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Apr 14, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Jan 26, 2021 | Hoover Vacuums
13 people viewed this question
