Question about Refrigerators
Garrison bottom mount water cooler not dispensing any water . When plugged in , do not hear pump running .Took top off - lid to canister is secure & screwed down & can see (sorta)water in plastic tube leading to dispenser .Prior to this AM noticed water getting slower when being dispensed
Posted by Theresa Massey on
David Spradling
    Top Expert:
  • Refrigerators Master
  • 11,960 Answers
Possible blockage in line or weak water pump
Posted on Jan 24, 2021
How to install samsung Part Number DC31-00054A (AP4202690)
1. Unplug the washer. 2. Unscrew the 2 screws at the top back of the washer that secures the top of washer pane, slide it back and lift off, remove and set aside. 3. Pull out the dispenser tray and depress the tab at the back to full remove. 4. Remove the dispenser mounting screws, slide the dispenser back. 5. Carefully pull the control panel off from the top, disconnect the two wire harnesses and set the control panel aside. 6. Use needle nose pliers to remove the retaining wire and spring from the door boot seal, pull the seal away from the lip of the front panel. 7. Remove the 3 door mounting screws to release door latch assembly from the front panel. 8. Open and detach the filter access door and release the drain tube from the retaining tab. 9. Remove the screws inside the filter housing securing the front panel. 10. Carefully lift the front of the washer up and support it. 11. You can now remove the screws at the bottom securing the front panel(if your has these, mine were missing). 12. Now is also a good time to detach the pump assembly wire retainer from the base(small white plastic tab sticking downward). 13. Remove the support and gently lower the washer back down. 14. Remove the mounting screws on top of the front panel. 15. Now, use a flat head screw driver to depress the locking tabs to release the front panel from the frame. 16. Detach the recirculation hose from the retaining brackets on the inside of the front panel and set the panel aside. 17. Uncap the drain tube, and drain the excess water, then recap the tube. 18. Release the retaining clamps securing the hoses to the pump assembly and slide the hoses off.(be prepared for some water to spill). 19. Remove the two screws securing the pump assembly to the mounting bracket. 20. Now, push the assembly back to release it from the base. 21. Next, detach the drain pump cover(top white plastic cover) and disconnect the wires, now remove the 3 mounting screws and pull off the old pump. 21. Install the new drain pump by properly aligning it on the assembly. 22. Replace the mounting screws to secure. 23. Connect the wires to the new pump and snap on the cover. 24. Position the pump assembly into the cabinet base by inserting the mounting tab into the slots in the base, then push forward. 25. Replace the screws to secure the assembly to the mounting bracket. 26. Snap the wire retainer into the base. 27. Reattach all of the hoses to the appropriate ports on the assembly and position the retaining clamps to secure. 28. Replace the front panel, by aligning the slots in the panel with the tabs on the base. 29. Secure the recirculation hose in the retaining brackets, making sure the door latch is inside the cabinet and snap the top half the panel into position. 30. Replace the screws on top. 31. Lift and support the washer, then replace the screws on bottom. 32. Remove the support and lower the washer. 33. Replace the 2 screws in the filter housing. 34. Secure the drain tube under the retaining tab. 35. Reattach the filter access door and snap it closed. 36. Now, realign the door latch assembly in the front panel, and replace the mounting screws. 37. Align the boot seal on the front lip of the panel. 38. Replace the retaining wire and spring to secure. 39. Replace the control panel, by first reconnecting the wire harnesses. 40. Now, insert the control panel tabs into the slots into the trim and snap the top half of the panel into place. 41. Reposition the dispenser and replace the mounting screws. 42. Slide the tray into place. 43. Reposition the top panel by aligning the edge of the panel with tabs on the support bracket, then push forward.
44. Replace the screws at the back. 45. Plug the power cord back in. Your done!
Your washer should be ready to use now!!! Good Job!
You should find this video useful, even if it is for a different model washer, it is what I used as a reference. Drain Pump Replacement part DC31 00054D Samsung Washer Repair
Sep 06, 2014 | Samsung WF448AAP Front Load Washer
Assistance help..4 hours of failure
If the unit is used, sometimes crud will cease the unit. you could clean it out real good and see if that helps.
I am not familiar with the unit, but another thought would be to see if there is a mechanism for "self priming" and make sure no hoses are kinked etc...
I hope you have better luck.
Apr 26, 2014 | API Filstar xP-XL extra large Canister...
Water cooler runs for 20 sec and then stops says that bottler is empty. not pumping water?
either you faild to unpack it properly and left some thing in the dispenser area where the bottle drops in. It doesn`t pump water, it gavitys out of the bottle.
Apr 23, 2014 | Vitapur Energy Star Bottom Load Water...
Pump repair
Instructions1 Unplug the electrical cord of the washing machine from the electrical outlet before attempting to repair the water pump.
2 Turn the water supply off at the shut-off valves behind the washing machine by hand.
3 Press in on the end caps of the washer while pulling forward to remove the caps from the control console and locate the screws in the front of the console on each end.
4 Unfasten the screws on the control console with a screwdriver and flip the console back so that it rests on the rear hinges.
5 Unplug the lid switch connector from the top of the dryer near the back, lifting the plug off the metal prongs by hand. Use a screwdriver to pry up the metal clips that are holding the top on the dryer.
6 Lift the top lid off the washer base, set the top out of the way, and locate the water pump at the bottom of the cabinet on the motor shaft.
7 Slide the metal clips off the top of the water pump with a screwdriver and remove the pump from the motor shaft.
8 Place a plastic container underneath the water pump to catch any water from the pump and detach the hoses, unfastening the clamps with a screwdriver.
9 Remove the hoses from the pump, allowing the excess water to drain into the plastic container, and remove the pump from the washing machine.
10 Attach the hoses to the new water pump, securing the clamps with a screwdriver. Place the new pump on the motor shaft, sliding the metal clips back over the pump.
11 Take the plastic container out of the washer cabinet, disposing of the water. Place the top lid of the washer back over the cabinet, securing it with the metal clips on the top.
12 Plug the lid switch connector back into the top of the washer near the back, attaching the connector by hand. Flip the control console back down over the washer, securing the console with screws on the ends.
13 Fasten the end caps back over the control console by hand and turn the water supply back on at the shut-off valves.
14 Plug the electrical cord of the washer into the electrical outlet.
THanks
Apr 02, 2012 | Whirlpool LHW0050PQ Front Load Washer
How do you change a pump on a Samsung WF448AAP washer? Need to get in from the back?
Dec 07, 2010 | Samsung WF448AAP Front Load Washer
Water dispenser stopped dispensing water but ice maker is still working fine
I had the same problem. Ice maker works fine. Removed the kick plate at the bottom of the fridge to expose the water line. I disconnected it and then pressed the dispense button. Water pumped out of the line so i know water was getting all the way to the freezer door. I went overkill but it worked. I removed the freezer door and placed it outside. (disconnected the power to the door by disconnecting the plug at the top. and then removed two screws/bolts at the top and the door lifts up and off) I set the door on a patio table with the bottom facing up. I picked up some 16 gauge wire ($6 at Home Depot) and ran it up the water tube from the bottom of the door. The bottom is more of a straight shot up the water line. I also took a turkey syringe used to inject juice into a turkey and i shot very hot water up the line with the door upside down. This allowed water to run up the line and unfreeze it if it was frozen. I let it sit outside for 30 minutes and put the door back on and now it works like a champ. The line was either frozen or it was obstructed. The water line is surprisingly small. Took less than an hour and I now have water again. Not tough at all...
Oct 06, 2010 | Whirlpool GS6SHEXNL Side by Side...
My black and decker water cooler makes noise like its boiling water which I know it does but it's much more pronouced and more frequent than before.
Slight boiling noise aside, a loud and unbearable rattling noise plagued my B&D Hot and Cold Water Cooler (top load). DIY Solution: The issue was some sort of copper coil vibrating against the front panel cover (just behind where you would place a glass. This copper colored coil is attached a canister looking thingy ma-bob, with a long black arm that is runs to the bottom right of the back cover. By removing all four screws on the back cover, you may angle (bottom out) the cover enough to gain access to this arm. GENTLY... lift the arm/rod so that the copper coil is no longer touching the front panel (and thus it is free to vibrate without that annoying noise). CAUTION: unplug the unit and ground yourself to avoid shock. Once you can see the coil is no longer touching, plug-er back in and see if the noise has stopped. Perform above at own risk.!!!!!
Aug 01, 2009 | Whynter FX-6SW Free Standing Hot & Cold...
Dishwasher problem
Symptoms:
Dispenser lid is open. Caked powder at (what would be during normal operation) bottom edge of soap dispenser or caked powder fallen onto dishes or dishwasher bottom. There may be loose powder in rest of dispenser or spilled down inside door or onto dishes underneath dispenser.
Solution:
Keep the area around the soap dispenser lid clear when loading the top tray.
Explanation:
The soap dispenser needs to swing open during the wash cycle. In many dishwashers the top tray has an indentation as wide as the lid of the dispenser. This allows the top tray to be as large deep as possible while still allowing space for the dispenser lid to open. People often pack their dishwasher with things overhanging this gap.
During the wash cycle the catch will release but the overhanging cutlery or crockery prevents the lid from opening all but a few degrees. Some water will splash in but not enough to wash out the soap powder. The soap powder at the bottom of the dispenser will then cake.
When the front door is opened the spring loaded lid, which is partly open, will of course swing fully open and you'll be convinced that the lid opened normally during operation. If this is the problem then if you're very careful and open the door very slowly you can actually hear the lid flip open. Also, depending on when the lid opens, how far it opened during operation and how fast you open the door you may find soap powder spilled down to cover the dishes at the front or down the inside of the door. This happens when you first open the door and obviously there couldn't be loose powder there if the powder had emerged while there was water washing around. Seeing the lid open as you open the door is a lot harder but can be done on some machines.
Oct 24, 2008 | Whirlpool 24 in. DU1100XTP Built-in...
GE Monogram DIshwasher
Before taking anything to bits, check you aren't just loading the machine in such a way that something (for us, it's usually a frying pan) is stopping the soap dispenser from springing open all the way. A.
Apr 21, 2007 | GE 24 in. Monogram ZBD6880KSS Stainless...
Refrigerators Logo
12 people viewed this question
Top Refrigerators Experts
Marvin
Marvin
john h
