Question about Kenmore Dishwashers
Watching more closely it blinks seven times and hesitates then again and again.
SOURCE: Clean light blinks constantly
press heated dry
press normal wash
press heated dry again
press normal wash again..........
.....wait a few seconds
all the lights should come on
press cancel (should hear pump)
hit cancel again
Hope this helps, it worked for me, but it may depend on your model.
Posted on Feb 05, 2009
SOURCE: whirlpool gu2400 clean light is blinking 7 times
Yes this is a heater fault detection error. The unit may not be heating the water resulting in unsanitary dishes so the unit shuts down in this fault. Also the door may not have completely shut resulting in the heater not working, but everything else does (the heater common line is broken at the door switch. Clear the fault by entering diagnostics with this key dance heated dry, normal, heated dry, normal. All the leds will light, you can then press cancel and try another wash cycle. If fault occurs again, you must repair heater problem.
Posted on Dec 23, 2007
SOURCE: Sony Vega Service Codes
KV-32HS510 and KV-27HS420, seven times blink error code shows problem in Horizontal deflection circuit.
There are many possibilities like dry solder joints, weak capacitors, Horizontal transistor short or flyback transformer fried etc.
If you have little experience of TV repair and good solder skills and have necessary tools to test / check defective parts, then you can make it. you also need to have related service manual to see board location, schematics and part numbers.
Posted on Dec 12, 2008
SOURCE: Dishwasher Clean light blinks constantly.
Try turning off the power to the dishwasher at the circuit breaker box. leave the power off for 5 10 mins and then turn breaker back on and try to restart dishwasher. This may reset the board and it may work
Jul 19, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
May 21, 2012 | Kenmore Washing Machines
Apr 07, 2011 | Kenmore 67032 Dryer
Oct 02, 2017 | Kenmore Dishwashers
Aug 17, 2009 | Kenmore Dishwashers
Feb 22, 2009 | Kenmore Dishwashers
Feb 06, 2009 | Kenmore KCM12 Coffee Maker
Sep 22, 2007 | Dishwashers
Jan 08, 2021 | Kenmore Dishwashers
22 people viewed this question
