Question about Cuisinart Coffee Makers & Espresso Machines
Is done brewing for at least an hr. It continues to make popping sounds and releasing steam sounds. Extremely loud. I don't think it's normal. Month old
SOURCE: turn off beeping alarm when the coffee maker is done brewing
you can't ,its up in the top behind the controls.
you have to take the pot totally apart.
only a trained tech should attempt this.
Posted on Apr 02, 2008
SOURCE: Cuisinart DCC-2000 12-Cup Coffee Maker shuts off after brewing
Turn the function knob to Auto Off
Hold down the hour button til you see the clock display blinking
you can then use the Hour and Minute buttons to program how long you want the coffee maker to stay on.
You can choose from 0 minutes (seems to be what you have it set on now) to 4 hours.
Posted on Nov 15, 2008
SOURCE: cuisinart coffee maker won't brew
Here is the basic troubleshooting for the Cuisinart coffee makers:
Make sure all baskets are in proper place – especially if unit is beeping.
Do not use a paper and a gold-tone or other permanent filter at the same time.
Unplug for LONGER THAN 15 full minutes to reset.
Clean by brewing 2 oz of distilled white vinegar/2 oz water.
If these methods fail, the unit probably requires replacement – call Cuisinart as they have a longer-than-standard warranty.
-Tha Mp3 Doctor
Posted on Dec 15, 2008
SOURCE: cuisinart Grind and Brew 10
Replacement time. a certain percentage of thse have this problem. There is a small, non-replaceable tube in the inside toward the bottom that has become melted/damaged.
Posted on Dec 17, 2008
SOURCE: cuisinart burr grind and brew coffee maker
The hopper between the burr grinder and where coffee chutes into the filter is jammed with coffee powder...
First, take out the filter holder and carafe, and place a freash empty filter on the pot base to catch stuff.
Next, take out the beans holder and look for the release lever in the lower left section. Sliding it to the left slides open the door, where you'll probably find loads of powder. You can poke your finger through to get the majority, then use the cleaning brush to get it really clean.
Thanks what fixed mine! (I notice I have to do this about once every few months.)
Posted on Aug 03, 2009
Jan 03, 2018 | Cuisinart Brew Central 12-cup Coffee Maker
Jan 04, 2011 | Cuisinart Grind and Brew 10 Cup Coffee...
Sep 14, 2010 | Cuisinart DCC-1200 Coffee Maker
Sep 22, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Feb 25, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Jan 23, 2009 | Cuisinart DGB-600 Coffee Maker
Dec 08, 2008 | Cuisinart DCC-1200 Coffee Maker
Nov 03, 2008 | Cuisinart DCC-1200 Coffee Maker
Oct 20, 2008 | Cuisinart DCC-1200 Coffee Maker
19 people viewed this question
