Question about Siren SIR103 MP3 Player
Boot error. How can I reset it? - Siren SIR103 MP3 Player
Posted by Enock Nyambichu on
My 1998 saab wont stop beeping
Your Siren alarm might be faulty. Do you have any error messages on your SID display? The siren alarm located behind the driver side fender. The Siren alarm can be replaced or bypass the unit with a Tech2 scanner. A new Siren alarm is very expensive ($360+) from the dealership. However, you can get your original unit rebuilt through BBA vendor for about $85.00 with life time warranty.
Good luck
Apr 09, 2014 | 1998 Saab 900
Tip
LANTERN OPERATION 1. PUSH THE LANTFRN/FLASHSLIGHT/OFF (11) TO ?LANTERN 1+2? OR...
LANTERN OPERATION
1. PUSH THE LANTFRN/FLASHSLIGHT/OFF (11) TO “LANTERN 1+2” OR “LANTERN I”. THE LANTERN WILL BE TURNED ON.
2. PUSH THE LANTERN/FLASHLIGHT/OFF (11) TO “FLASHLIGHT’ TO TURN ON I’HE FRONT LIGHT.
3. PUSH THE LANTERN/FLASHLIGHT/OFF (11) TO “OFF’ THEN BOTII LANTERN AND FLASHLIGHT WILL BE TURNED OFF.
4. PUSH THE BLINKER/SIREN/OFF (12) TO “BLINKER” AND THE FLASH LIGHT (10) WILL BLINK.
5. PUSH THE BLINKER/SIREN/OFF (12) TO “SIREN” AND THE SIREN WILL BE TURNED ON.
6. PUSH THE BLINKER/SIREN/OFF (12) TO “OFF” AND BOTH THE FLASH LIGHT (10) AND THE SIREN WILL BE TURNED OFF.
7. PULL OUT THE LANTERN (16) AND ADJUST THE LANTERN ANGLE.
on Mar 05, 2009 | Jeep KNG36-JXLWBC AM/FM/Weather Radio
How do I uninstall an Audivox 6 tone mini siren from my 2004 Honda Accord. I didn't install this item and now it is always arming itself locking me out of the vehicle!
The siren is merely the part of the alarm that gives you an audible alert when you arm, disarm the alarm. It also alerts you to intrusion and tampering. The siren does not arm itself and lock you out.
Locate your valet switch and turn the ignition on, press and hold the valet switch, count to five and release. the unit will be in valet at this point. Locate the model number and report back for the instructions to disable the passive arming.
Aug 12, 2012 | As9903 Mini Six Tone Siren For Car Alarm
Schematics for cjb100pd
Red is your positive, black is negative, both brown wires are to the speaker, and the yellow and green wire are for any emergency strobe lights you may want to hook up to it. P.S. if you wire up the brown wires and siren doesn't work make sure volume is turned up and try it again if it doesn't work then switch the brown wires around. Both toggle switches on the far right is to only turn the lights on. not the siren. Make sure the siren nob is turned all the way left thats off. The rest of the are just siren modes. The toggle switch all the way to the left. Push down horn comes on release it then horn goes off. Push up siren comes on for like 7-10 seconds and the goes off. Horn and your microphone always override any siren that may be on.
Mar 12, 2012 | Cars & Trucks
Wiring
There are 3 wires on this siren. Red, Black, and Yellow. The red and black wires will give you the normal sound you hear from a siren. If you hook up the black and yellow, it will give you a continuous long tone. Normally, you hook up the black to Bell - and and the red to Bell +.
May 19, 2011 | Siren Dsc Sd 15w Ulf Surface Mount Siren...
How to make a battery siren bicycle locks at home
Simple alarm using a Mercury switch, a tilt switch, a relay, a siren, a keyswitch, to reset, and a battery. The relay will latch, and until the Key switch is turned OFF it will continue to sound. When tilted, the Mercury switch conducts, as tipped past a certain angle, and alarm sounds, use a all-in-one siren.
Apr 04, 2010 | Starter Sentry Vehicle Anti-Theft System
How to turn up volume on siren. 791XV
I dont think you can turn it up. But I added 2 more sirens. The original is very small and quiet.
Apr 12, 2009 | 791XV The 791XV is a 2-way Security and...
Getting code 10 error
Uninstall and then reinstall the software from the CD - this is the fix suggested by both the manufacturer and Microsoft for Code 10 errors.
-Tha Mp3 Doctor
Jun 10, 2008 | Siren Edge MP3 Player
My siren 4GB mp3 player
Why does my player display "Boot error, Shutting Down" when I switch it on?
"– The player has been formatted with the wrong system, for example NTFS, Mac OS or Unix. To enable it again for playing audio tracks, please format the player in FAT/FAT32 format."
– If formatting was not successful, please reinstall the firmware while the player is in Recovery mode (Refer to the chapter "If the player does not work" in your instruction manual).
Hope this helps. M~
Apr 30, 2008 | Siren Edge MP3 Player
Siren SIR103  MP3 Player Logo
16 people viewed this question
Top Siren Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
Are you a Siren Audio Player and Recorder Expert? Answer questions, earn points and help others
