Our Kohler dtv shower turns off on its own as soon as it reaches the set temperature. This started happening about 3 weeks ago. It takes forever to get hot then slowly increases the temp and the last 3 degrees it quickly jumps up to set temp and shuts off. Absolutely driving me crazy.
Run diagnostics.
Settings > System > Diagnostics
If no problem found, try System Reset.
Settings > System > Reset > Reset System > Cancel or Reset System
IMPORTANT!Resetting the system will return your interface to the original factory default settings. This will also delete any custom configurations or settings.
Posted on Jan 25, 2021
SOURCE: Oven does not maintain temperature. Part 2
sometimes when they get hot that is when they fail
Posted on Oct 31, 2007
SOURCE: Won't shut off when reaching preset temp
The heater shuts off when it reaches two degrees above the set temperature and turns back on when it is two degrees below.
Posted on Mar 25, 2008
SOURCE: GE JKP26GOP1BG Electric Oven won't maintain temperature
You will need to replace the temp probe Call704-891-6557 we'll tell you how to do it safely.
Posted on Mar 14, 2009
SOURCE: Freezer outside walls are very hot. Not maintaining temp
Hi, The walls are getting hot because that is where the condesor coils are. The condensor coils are where the heat is disperst that is trap as the coolant pumps through the evaporator coils inside. The fact that it is holding 0 degrees is a good sign. Is this freezer in a garage?
Check the door seals to make sure no heat is getting into the freezer other then when the door is opened.
I hope this helps you. Please let me know if I can assist you further.
Vic
Posted on Jun 24, 2009
Jul 20, 2014 | Toshiba 32AV500U 32 in. LCD HDTV
Nov 04, 2012 | Initial DTV-171 17 in. TV/DVD Combo
Nov 02, 2012 | Vizio GV46L 46 in. LCD Television
Nov 20, 2011 | Mitsubishi WS-55511 55" Rear Projection...
Mar 10, 2011 | ViewSonic N2751W 27 in. LCD Television
Aug 15, 2010 | Televison & Video
Mar 04, 2010 | Bosch AquaStar 2400ES-NG
Oct 10, 2009 | Protron PLTV-4250 42 in. LCD Television
Feb 28, 2008 | Mintek DTV-263 26 in. LCD Television
Dec 07, 2007 | Zenith TV SPEAKER SYSTEM, FOR 50" PLASMA...
13 people viewed this question
