Question about Fujitsu Heating & Cooling
Model AOU24RLXFZ. What does code 76 mean?
Both inside units.
Posted by Ray Cote on
2 Related Answers
Anonymous
  • 50 Answers
SOURCE: Our a/c-heat pump unit was replaced for our home.
The issue is with the thermostat wiring. Depending on the heatpump, the Y1 wire is used to start the compressor, usually in the heating mode and the O wire operates the reversing valve, to bring on cooling. The crossed wire could be at the thermostat or at the unit. You likely have had techs that have little or no heat pump experience, this is a simple issue. Locate a good heat pump tech and have him/her fix it. Document the repair and send a demand for repayment from the ones that have been out. They need the education such a bill will bring them
Posted on Jul 19, 2010
Anonymous
SOURCE: I have a Rheem tanklees water heater, model
Contact Paloma/Rheem 866-720-2076. Super nice! I just called regarding mine. Having same problem Rheem Paloma sending parts out tomorrow overnite. Try turn it on/ off by moving tiny switch under the unit that tells you the temperature. Run your fingers along the bottom to find it. That is a temporary fix. Below is a website with all the error codes, so you know what is wrong. Good luck and blessings!
http://www.palomastore.com/paloma_error_codes.html
76
Communication Fault with Remote Control Check remote control wiring for loose or damaged connections. Bypass remote control cable by connection remote directly to remote control terminals on PCB (replace cable if found to be faulty). Replace remote control. Replace PCB
76
76
76
Posted on Nov 09, 2010
Can a Fujitsu compressor unit be connected to multiple inside evaporator units that have different tonnage ratings. 18,000 BTU compressor and 9,000 & 12,000 BTU evaporator units inside.
call fujitsu engineering division direct and ask them about what is connected and if it works ok
logically as each evaporator has it's own tx valve as long as the compressor is large enough to run all together it should work but get the right information from the fujitsu experts
Oct 11, 2016 | Fujitsu Heating & Cooling
Tip
Get hot water from your Rheem tankless during a code 76 error
This doesn't always work, but on the Rheem tankless Gas/Propane water heater, if you're experiencing a code 76 error; disconnect the remote control unit (either from the water heater or the remote) by lifting the wires for the remote connection. Typically you'll get a C1-C8 error code, followed by a code 76; if you're getting a straight code 76 and nothing else, this procedure probably won't work.
Code 76 is a total power supply failure on the printed circuit board (PCB) assembly, which is the communication/power supply for the remote control unit. But, if you're getting a supplemental code (C1-C8) this procedure will most likely supply you with hot water until the replacement PCB arrives.
on Dec 01, 2009 | Rheem Tankless water heater for 1-2...
Problem with Fujitsu minisplit heating
did you try to set to maximum heat? (suspect the thermostat is defective)
Oct 03, 2015 | Fujitsu AOU24RLXFZ Dual, Tri and Quad Zone...
Remote is flashing C8 and 76, alternating. I turn the unit off, then back on, and I get hot water for about 10 seconds, then it goes cold and the same error message occurs. Unit is Rheem Main Remote...
Before calling service technician, open following links for Rheem tankless resources including error codes and Rheem chat.
Disconnect wires from remote to see if system stabilizes. Unit will heat to default temperature without remote.
Error codes are considered start-point for troubleshooting.
C8 76 can mean PC board failure.
76 can mean communication failure with remote control
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
http://waterheatertimer.org/pdf/ErrorcodeTroubleshooting.pdf
http://waterheatertimer.org/pdf/Rheem-error-code-C7-76.pdf
Jul 31, 2011 | Rheem Tankless Water Heater Main Remote...
I have a Rheem rtg 74dvp but its not heating and the display show me 1 76 and 2 76, and come all the time to 76 F and another times its blinking the temperature, but not heat
Error code 76 is communication problem between remote control and tankless unit.
Multiple error codes could indicate that main PC board is bad.
Before calling service technician, open following link for troubleshooting resources including link to Rheem chat, manuals, error codes, etc.
Jul 15, 2011 | Rheem Tankless Water Heater RTG-74DVP...
Our a/c-heat pump unit was replaced for our home. This unit throws hot air in the summer and cold air during the winter. We have called service techs numerous times and no one seems to find the issue....
Jul 12, 2010 | Whirlwind FH-778 Air Conditioner
C4 76
76 is a bad connection between the controller and the unit. try unplugging the controller and running it, also check the wiring between the two units. if that is not it. it means that one of the control boards it shot
Jul 18, 2009 | Water Heaters
Unit will not operate
http://www.fujitsu-general.com/global/products/index.html
Find your manual and check the code of the blinking green light. It will give you the resolution for your code. If you still have issues, post a comment back on this thread and I will be able to help you. You will need your model number for the website.
Mar 21, 2009 | Fujitsu Heating & Cooling
Heater not working
Model ASTA24LCC found that the problem was the valve inside the out door unit that reverses the flow of the R410A, the service fellow gave it a bit of a tap and restarted unit to find that it would work, hope this help some one else out there with a similar problem, the inside unit operation and timer light would flash together twice then just the operation light would flash five times, was told by Fujitsu that this was the code for refrigerant problem.
Jul 28, 2008 | Fujitsu Heating & Cooling
Heating & Cooling Logo
20 people viewed this question
Top Fujitsu Heating & Cooling Experts
Marvin
Marvin
Fahr Quad
jdthefixer
Are you a Fujitsu Heating and Cooling Expert? Answer questions, earn points and help others
