Question about ZAGG Keys Solo Keyboard
On my bluetooth zagg keyboard IPAD) none of the letter keys work. the upper keys work, like I can turn my volume up and down' and the keyboard has plenty of charge, but I cant type anything on it
Posted by Andrew on
1 Related Answer
Justin
  • 3 Answers
SOURCE: my wireless keyboard does not work with vmware
Are you using Vmware View when logging on? It could be recognizing it as a usb device. Look on the menu bar that shows up if you bump the top middle of the screen under usb devices. If your keyboard is listed remove it or add it. One should make it work.
Posted on Nov 26, 2012
How do I get my ellipsis 8 tablet to recognize or pair with my zagg keyboard?
ZAGG Folio Case with Keyboard for Ellipsis 8 - Verizon ...
www.verizonwireless.com > ... > ZAGG
Verizon Wireless
Rating: 2.2 - β€Ž5 reviews - β€Ž$99.99 - β€ŽIn stock
Use arrow keys to access sub-menus and sub-menu links, this may require a mode change. Wireless ... My Verizon .... Super versatile with so many convenient features, no matter what situation you might find yourself in, the ZAGG Keyboard Folio can ... One ZAGG Keyboard Folio for the Ellipsis 8, plus one charging cable.
Amazon.com: Zagg Folio Ellipsis 8 Bluetooth Keyboard ...
www.amazon.com/...Ellipsis...Keyboard.../B010QY8E...
Amazon.com, Inc.Amazon.com: Zagg Folio Ellipsis 8 Bluetooth Keyboard backlit keys Stand ... Thekeyboard/case fits like a glove and protects my tablet. .... Check out these pages tosee more: verizon tablet, ellipsis 8 case with keyboard with design case, folio ...
ZAGG Product Manuals and Downloads
Jan 01, 2016 | Radio Communications
My zagg case/keyboard turns on but doesn't connect to my ipad
Don't forget to switch on bluetooth. Then look under devices if your keyboard comes on the screen. It could be the device is asking for you to type in a code like 0000 or 1234. Or whatever.
Only when you did pair the device to your iPad, it will be able to see the keyboard when you switched it on.
Oct 18, 2014 | ZAGG Computers & Internet
Cannot get ZAGG keyboard pair to iPad
Check that the keyboard's battery is working and it's on. Turn on Bluetooth on the iPad (Settings > Bluetooth). Press the keyboard Connect button. Choose the ZAGG Keyboard on the iPad, and type the code on the keyboard.
This doc describes the process: http://cfprod.zagg.com/downloads/ZAGGfolio%20instructions/ZAGGfolio%20instructions.pdf
Good luck! :)
Mar 25, 2014 | Apple iPad Tablets & eReaders
Pairing Zagg keyboard and iPad 4
There must have been some updates to the IPad that made it not recognize the board. Either take the Ipad back to before the updates were put in or look for a patch at the manufactures site.
Jan 27, 2014 | Computers & Internet
My Zagg keyboard won't connect with my iPad2 and the connect light continuously blinks. Please help.
On your ipad, go to bluetooth close out of it completely and reconnect to your Zagg keyboard! Worked for me, hope it works for others.
Jan 21, 2014 | Computers & Internet
The letters B & N do not show up on the iPad3 using the Zagg Keyboard. This includes upper and lower case. All other letters show up fine
Joke-something against barnes and noble?
Try using something to stop the static buildup on those two keys. That could be the issue, esp. if you use them often. or was it always this way? a thin metal file should be rubbed under the keys GENTLY so you don't pop them. Then try again or consult your warranty.
Oct 23, 2013 | ZAGG folio Keyboard for iPad 3 and iPad 2...
Zagg keyboard Will not work after connected by Bluetooth in ipad2
I have a Zagg keyboard for my iPad mini. I found the same thing happened but then realized it only works in most apps, not all. For example it doesnt work when typing in a password in settings. Try you keyboard in an app like notes. Also make sure you haveheld down the power for long enough that the light is red for 5 seconds.
Sep 28, 2013 | Apple iPad 2 Wifi 16GB
Zagg keyboard doesnt work
Mine went dead after about 3 weeks. Once I realized there was a charging port which is not IPhone, but droid type. Began charging. Would not recognize until I went to blue tooth setting and said forget device. Then turn bluetooth on and then hold bluetooth key down on for 3 seconds or so on keyboard. Then it worked. I guess dont let it run till it dies.
Apr 16, 2013 | ZAGG New Apple Ipad 2/ Brand New Ipad...
ZAGG Keys Solo Keyboard Logo
19 people viewed this question
Top ZAGG Computers & Internet Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a ZAGG Computer and Internet Expert? Answer questions, earn points and help others
