Question about Makita Saws
I have a Makita circular saw that when you try to start it it barely turns and flips the breaker or tries to all the lights dim!! Is there a start compacitor for that saw
Posted by Brian Hutsin on
Vernon Taylor
  • Makita Master
  • 7,446 Answers
All portable power tools including saws and most tradesman type saw benches use the light and powerful series wound brush-type motor that doesn't use a start capacitor.
The single phase induction motor that does use a start capacitor is far too bulky and heavy for portable tools but is found in many of the static workshop tools.
The powerful brush type motor is electrically very noisy and is almost permanently at the edge of self destructing. Good suppression to prevent radio and tv interference is necessary and this also helps protect the motor but a mains transient or power surge while in use can cause an internal surge destroying the insulation of the windings rendering the motor useless in a millisecond.
This could be what happened to your saw though it could equally be an internal short circuit in the power cord or inside the saw and these things must be checked before either writing off the tool or sending it for repair.
Posted on Jan 12, 2021
5 Related Answers
Anonymous
SOURCE: makita table saw switch wiring
After much trial and error, a little smoke, and wrecking one replacement switch, I solved a similar problem with my Craftsman Cmpd Mitre saw. Different saw, but likely the same principles are involved.
If the switch is a double pole single throw switch, with one side normally open (N0) and the other normally closed (NC), and the saw has a separate wire for the brake, this will probably work.
One side of the switch should have contacts that are normally open (NO) and only connect when the switch is ON. The Hot (Black) wire from the plug connects to the wire on the machine side (red or maybe black) through this NO side. So, connect these two wires via this NO side and the saw will run when the switch is ON but will have no brake; so far so good.
There should be another wire (Not the neutral white) which is the brake wire. This gets connected to one of the connection sites of the Normally Closed (NC) side of the switch. From the other connection site of this NC side run a short "jumper" wire (of the same guage as the other wires) to the Machine Side of the NO side of the switch (same place as that Red or Black? wire above) .
What seems to happen is this:
There's no power to the machine or the brake when the switch is OFF. Turn it ON and power goes from Hot through the NO (now closed) side and the saw runs. The brake doesn't run when the saw runs because the NC switch is now open. Turn the switch OFF and the NC switch is in fact closed and power is transfered to the brake via the jumper wire from the still spinning armature which now acts as a generator (alternator?). Once the brake has done its job and the armature stops spinning there's no power anywhere until you turn the switch ON again.
Or at least that's the theory, and in my case it works; no more smoke.
Posted on Feb 04, 2009
efs_perpends
efs_perpends
  • 1997 Answers
SOURCE: where is the lock button for the skill saw
I can't seem to access the parts view for your model, because of its age.
But I'm thinking skil probably hasn't changed things all that much.
Take a look at the 5450 and see if this doesn't help any...click here ...and scroll to page 7.
Posted on Apr 10, 2009
Anonymous
  • 29 Answers
SOURCE: dewalt ds2400 wet saw will through in line breaker not start
sounds like the breakers working to good,i would by pass the reset switch,most likely that switch is bad anyways,we always plug our saws into a outlet box that has a breaker in it ,you know those reset switches are stupid, by pass the reset switch like it wasnt even there,and if that works i would replace the whole cord with a new 1,and buy a 5 dollar junction box that has a breaker in it,i dont know if there is a seperate plug on that saw where u plug the water pump into, if there is i would check that plug first before you bypass the switch.good luck chad
Posted on May 31, 2009
rowdy45176
David Ford
  • 2176 Answers
SOURCE: Makita Circular saw 5007NB, the cutting depth
you can try spraying some lubricant on the bolt/roll pin and see if that frees it up that is about all i used to do to them
Posted on Jul 01, 2009
Frank Bushnell
  • 5 Answers
SOURCE: I have tried numerous times to undo a nut on my
I have B&D D984 circular saw attachment.
1) Unplug the tool before doing anything ! ! !
2) Lock the blade with a rod or screwdriver through the hole in the guard.
3) Turn the bolt head anti-clockwise (it's a normal right-hand thread).
Reassembly:
4) Make sure it's unplugged !
5) Oil between the rotating washers on the black moving guard.
6) Place blade (with teeth pointing anti-clockwise) on the black moving guard and insert guard into unit with blade uppermost.
7) Insert bolt most of the way, not tight.
Ensure guard rotates upward and is stopped on the way down by the stop screw.
8) Tighten bolt, locking the blade as before.
Posted on Jul 09, 2015
4answers
Keyless chuck stuck closed
Try WD40 and let it soak then lightly tap the chuck with a screwdriver handle. Then try to release the chuck.
1helpful
Do you have a capacitor for makita circular saw 5903 r
there is no capacitor in that saw, you have other problems, what is it doing or not doing and I will try and help
My blade to my circular saw model number 5007nb was having trouble cutting through some wood which lead to it over heating how can i fix this thing and get it to start working tonight
Well you did not really say what is wrong?
Are you trying to stop the overheating, or did it get so bogged down from blade heat warpage, that the internal circuit breaker tripped?
If so, then look at the end of the motor, near the cooling vents, and press the little black circuit breaker reset. (not all have them)
Also check that the outlet still works, by plugging something else into it, because you may have tripped the circuit breaker for the outlet, or GFP.
Even with a freshly charged battery the saw barely has any power.
more likely will be the trigger, i had the same problem
with my hitatchi drill
2answers
Instructions or diagrams on how to replace a power cord for a makita circular saw.
here's a article on how to fix it.
http://www.amazines.com/Electronics/article_detail.cfm/78565?articleid=78565
My 10 inch mikita slide saw just quit working. I tested the trigger switch and it seems to be fine but the saw motor won't run. Does anyone have any ideas?
Try another tool in the same power outlet. It may have popped a breaker. Make sure the blade turns freely. Does the motor have brushes that should be looked at? Hope this helps!
Makita Circular saw 5007NB, the cutting depth guide is jammed. What can I do?
Saws Logo
Top Makita Saws Experts
ray gallant
Parson's Repair...
Parson's Repair...
Are you a Makita Saw Expert? Answer questions, earn points and help others
