Washing Machines Logo
John Eblen Posted on Jan 11, 2021
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have an old Amana ALW480DLW washing machine. How do I get the agitator out?
ADMIN Andrew
Level 3:
Top Expert:
  • Amana Master 66,776 Answers
  • Posted on Jan 12, 2021
ADMIN Andrew
Amana Master
Level 3:
Top Expert:
Answers
66776
Questions
Helped
5048767
Points
378758
Lots of videos showing how
https://www.google.com/search?q=How+do+I+get+the+agitator+out+on+an+old+Amana+ALW480DLW+washing+machine&source=lmns&tbm=vid&bih=625&biw=1366&hl=en&sa=X&ved=2ahUKEwi86Jvz_JXuAhVQArcAHQIzCw0Q_AUoAnoECAEQAg
5 Related Answers
A
Anonymous
  • Posted on May 17, 2008
SOURCE: washing machine agitates, but does not spin
my amana washing machine does not agitate, but it does spin
Anonymous
  • Posted on May 07, 2009
SOURCE: old model rca washer machine...will not agitate/wash the clothes,does spin.
If the washer fills up with water and you hear the motor running but the agitator doesn’t move, the agitator coupling is the most likely problem. First pump the water out by turning the timer to spin. Once the water is out, turn the washer off. Now pull up on the agitator until it comes off (it may be hard to pull off). Now that the agitator is off, you can see the agitator coupling, reach down and try to turn the coupling. If the coupling turns freely, it is striped out and needs to be replaced.
Anonymous
  • 23 Answers
  • Posted on Sep 29, 2009
SOURCE: I need to remove the agitator from my washing machine.
On most Amana washers you pull on the agitator with brute force. It "snaps" on. It helps if you fill the washer with hot water and let it set for a few minutes... drain and then try pulling it out. When i last took apart my Amana it took me and a friend to pull the agitator off.
Anonymous
  • Posted on Feb 26, 2010
SOURCE: Amana washing machine makes loud noice when trying to spin
sounds like you are dealing with the same problem as me .
take off the front panel (after unplugging power) take a flash lite and look at the large pulley at the back just below the pulley is the helix check to see if they are worn .
http://fixitnow.com/wp/2008/10/21/amana-washer-makes-loud-ratcheting-noise-during-spin-but-doesnt-actually-spin/
Neciforo Llanto
  • 942 Answers
  • Posted on Mar 30, 2010
SOURCE: amana washing machine will not spin. it agitates
If your washer does not drain you need to check this parts.
  1. Inspect the drain hose for kinks
  2. Test the timer control
  3. Test the lid switch(some models)
  4. Inspect the water pump
  5. Inspect the drive belt(belt drive only)
  6. Inspect the motor coupler
Amana washer quit agitating and also drains and fills endlessly. Only 2 years old. What part is failing?
First check the drain hose isn't too far down the drain pipe it should only be about 6 inches down too much and it will siphon out
Amana washing machine will not spin. It agitates & the water drains out fine.
May be the spinning coil is short circuited kindly replace the motor even if you find the same probelm means then you are suppose to change the operational panel
4helpful
I've had an Amana Washer model ALW880QAW for about 6 yrs. Recently I've noticed old clumps of old detergent and fabric softener in the wash. I've already cleaned the fabric softener dispenser but the...
I couldn't wait for a rely on my posted question on March 6,2009. I was able to ask around to figure out how to clean this up. This Amana washer model has an agitator that is just clipped on. I just got my fingers underneath the agitator and pulled it off. After getting the agitator off, I was able to clean all of the old built up detergent and fabric softner with some old fashion scrubbing. Then I used some CLR to get what ever I missed. I pushed the agitator back until it clicked back into place and ran one washing cylce to clean things up.....Works great....No more old clumpy stuff showing up in the wash....
Wont agitate on its own
IT SOUNDS TO ME LIKE THE START CONTACT IN THE TIMER IS NOT MAKING A CONNECTION UNTIL YOU PULL OUT ON THE SHAFT OF THE TIMER. MOST TIMES IT NEEDS A NEW TIMER.
2answers
For amana top loading washing machine, how do you get to tub seal
hi potterstreas,any amana a couple years old is an maytay.they have had lots of problems with their thriple lip seal[water ,tub seal]you can order and parts on line by model# use our links if you like or google your brand/modelor sears online.have fun.God bless
1helpful
Washing machine agitates, but does not spin
Top Amana Washing Machines Experts
Virgil Watts
ZJ Limited
ZJ Limited
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
