You may need to recalibrate the hands. Sometimes the hands are out of sync with timekeeping. Go to the Casio website, download the manual for your model, and follow instructions for resetting the position of the hands (might be referred to as zeroing or recalibaration).
You have to know that analog time "follows" digital time.Any hour/minutes correction on the display has direct effect on time/minutes hands.Some times, mostly after battery replacement,hands might have declination.That is why there is a function so called "Hands home position adjustment".Using this function you can align both hands to 12/00 position.If there is any declination (I think is your case) you can correct.Try to enable this function by pressing for 4-5 sec the upper left button(A) until "HAND SET" appears.If hands are not aligned exactly to 12/00 position, you must correct by pressing the lower right button (D) for forward movement or the upper right button (B) for backward movement.In fact, minutes hand is aligned,hour hand follows.When both hands are set to 12/00 (home position) press button A again.Time Mode returns to the display.Normally hands will now show exactly according to digital (display) time.I hope this will help.
Is it a wave scepter? Place it in the window facing Fort collins, with the 12 pointing to Fort collins. Keep it away from metal which interferes with radio signal. Put it in place in the window before going to bed at night. When it picks up the signal the hands spin to match corrected digital time.
Use internet net to pull up Casio manual, which is way easier to read than the tiny booklet.
same problem here.. everytime i adjust the analog clock it moved but the digital clock dont so it means i can correct the analog but i cant correct the digital clock please help us..
Just tried this procedure to replace a watch battery in a POD 535 and did not work...my version of the watch might be different, all I am saying is it did not work with my watch. The procedure that worked with my watch When you have replaced the battery reset the watch by placing a small screw driver across the two recessed contact next to the lower battery clip. The digital display will reset and you will see four zero's flashing...if not press the winder button once, or reset the watch again. This process is to get all the hands at twelve O clock position...press and hold the top right hand button and the hands will start revolving...you can let go of the button once the hand are moving. Pressing the top button again will stop the hands and a short press will move the hands in small increments. Once the hands get close to 12 press then press the button once and then press the same button in short pulses to align all the hands on the 12 position. Wait a short time and the watch will find the time signal and both the digital display and hands will be aligned and showing the correct time.
The manual will tell you how to do this. To obtain a copy type "support.tissot.ch/?mod_flashPDF/id_138" into your search engine and this should take you to the manual page for your watch.
You must set the "Zero" position for your watch. Follow the instructions at this address and your problem should be corrected. http://www.geocities.com/watch_crazy/skyhawk/setting/setting.htm
Set in correct order:
1) Hand Home Position
2) Digital Time Set
1) Hand Home Position:
Press and hold A and B for 5 seconds, Press A to move Second Hand to 12: position: (if not there). Press B to enter Hour/Min set mode. Press A to move both hands to 12: position. Hold A to move hands fast, Press A again to stop hands. All 3 hands are now at 12' oclock.
Press B to exit Hand Home Position mode and enter Timekeeping Mode.
2) Digital Time Set: (hands will self set when done)
Press and hold B for 5 seconds to enter setting mode.
Press A to advance current item or scroll through choices. Press B to set item and advance to next item.
<Order of Items to Set>
GMT Differential -> Daylight Savings auto/on/off -> Seconds -> Hour -> Minutes -> Year -> Month -> Day -> Day of week language -> Auto receive -> (back to Timekeeping Mode).
<Setting each Item>
GMT Differential: Press A untill your time zone is reached (E=eastern, C=central, M=mountain, P=pacific). Press B to set (advances to next item).
Daylight Savings: Press A untill desired DST mode is reached: ("At" auto, "On" after spring change, "Of" after fall change) Press B to set (advances to next item).
Repeat to set: Seconds (resets to :00), Hour, Minutes, Year, Month, Day, Day of Week Language, and Auto Receive (on/off).
For each item, Press A to advance, and B to set.
Pressing B to set last item exits Setting Mode and enters Timekeeping Mode. Hands advance to current time.
