Why is my washing machine not draining the water at all from it ?
Posted by Tammy Smith on
Aron
  • 1,558 Answers
Your washing machine might have a clogged drain hose or the pump could possibly be broken and needs to be replaced . A broken lid switch or belt could also be the issue here . Or it could even be something very easy like the the hose being jammed. Whatever the reason is here the water will need to be drained from the washing machine before any work or and diagnosis can be done and call repair person to inspect your washing machine to see what the problem could be with it.
Posted on Jan 07, 2021
5 Related Answers
Robert Hopkins
  • 97 Answers
SOURCE: water is not draining out of kenmore 11020802990 washing machine
http://repair2000.com/demo_pump.htm
This will redirect you to a site to check and see if your drain pump is not functioning correctly. I would be willing to bet that therein lies your problem. Quite usually the pump itself runs fine however there is debris inside that will cause the pump not to function correctly. I. E. Dirt, Lint, heck I've even found a diamond necklace that had been lost that way.
Other things you can check without tearing the case off is to make sure that the hose is not kinked or clogged. I've seen sometimes where hair will get caught up in there as well.
Posted on Jul 29, 2009
Anonymous
  • 3741 Answers
SOURCE: washing machine will not drain. water wont drain
If your washer won't drain, check these:
It spins, but doesn't pump
It doesn't spin or pump
It pumps, but the water returns
It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out.
To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port.
Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job.
If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump.
It doesn't spin or pump If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it.
It pumps, but the water returns If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems:
  • If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
  • If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Posted on Aug 20, 2009
Anonymous
  • 127 Answers
SOURCE: Washing machine will not drain all the water. If
there is always a little water left in the drum assembly when done pumping. however it is usually well below the level of the clothes basket/drum so that there is none contacting the clothes when at rest.
if you can actually visibly see water within the clothes basket/drum when the cycle is complete, then check below.
have you lengthened the drain hose beyond the standard length to reach to your taller than normal sewer/drain inlet??? if so then you're getting more water returning to the unit when the pump shuts off and if the extra hose is long enough then theres enough water returning to your tub so that the basket sits in water at rest..
if so you'll need to install a check valve to keep the additional water from going backwards into your unit. some of these units have one built into the drain hose where it connects to the pump.. i tried looking yours up via the model # listed on the 1st page but got nowhere with that number.
you could also have a restriction in your pump or drain assembly that may be slowing things down some.. can't be of more help without proper model # though..
hope this helps,
best of luck,
ttfn
Posted on Oct 25, 2009
Anonymous
  • 41 Answers
SOURCE: Simpson Aquarius washing machine 7kg: water
SOUNDS LIKE A PLUMBING PROBLEM WITH DRAIN PIPE .YOU COULD FIT NONRETURN VALVE TO DRAIN FROM WASHER BUT THAT WOULD NOT STOP SINK FROM OVER FLOWING
Posted on Jan 09, 2010
marley mcelhinney
  • 490 Answers
SOURCE: washing machine not spinning or draining water
its your drain pump if you can hear it humming but no water is draining it is blocked or jammed by a foriegn object (most probably a 20 cent coin or bobby pin/s), if you can hear it working as normal but still no water it may have a blockage sumwhere along the drain pipe either that or the impellor has snapped off the shaft and is ratteling around and not actually turning, and with the spin that is directly related to yor drain pump issue as the washer will not even attempt to spin if water remains in the tub, incredibly easy to do hit me back if you want detailed instructions
Posted on Oct 14, 2011
Smart Drive machine on starting, water runs straight through into drain, thus not filling up
Most likely the water coming into the washer through the Water Inlet Valve could be siphoned out to the drain pump and out the drain hose because of an issue with the pump or plumbing. Is your washer overfilling?Is the washer detecting an overheat error? Observe carefully as to what part of the washing cycle the water is draining out. By watching the washer as it goes through its wash cycle, you can find out which part or error is causing the Washing Machine To Not Fill With Water and Keep Draining issue.
Washing Machine Will Not Fill With Water Keeps Draining How To Fix
Dec 03, 2017 | Washing Machines
My washer has slow drain and won't spin out completely. What might be the problem?
Repairing a Washer That Won't Drain or Spin ' ThriftyFun
www.thriftyfun.com/Repairing-a-Washer-That-Wont-Drain-or-Spin.html
Did everything look at everything that has to do with slow water draining. ReplyWas ... My washer washes fine, but it won't drain the water out or spin on any cycle. The guy who .... My Kenmore 417 washer will not completely empty and spin.
my washer won't spin and empty? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jan 15, 2008 - If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing ... My Whirlpool washing machine won't empty all of the water after ...
Mar 21, 2013
Clothes washer won't spin clothes to drain water out?
Jun 11, 2008
More results from answers.yahoo.com
Why won't my washer spin or drain? - Kenmore 110 Series ...
https://www.ifixit.com/.../Why+won't+my+washer+spin+or+drain
iFixitMar 16, 2014 - Belt, Water Pump If the washer won't drain the pump belt might havebroken or might have worn ... It will fill with water but won't spin or drain on its own. ... Keep in mind that any water in the washer will pour out of the hoses when removed. ... I would have had to take apart entire washer to fix clogged pump.
My washing machine won't drain - LaundryDoc.com
www.laundrydoc.com/Washing-Machine.../My-washing-machine-wont-...
If your washing machine will spin but it won't pump water out, then the drain line is probably clogged up. In most washing machines, a small sock or small piece ..
Jan 05, 2016 | Washing Machines
Holding water
Good Day,
Your washing machine is fully automatic?
the washing cycle is normal?
if yes do the same maybe it will help you.
for the fully automatic washing machine mostly have drain pump, please check the filter of your drain pump, how? remove the cup of your drain pump like a ordinary cup, screw it clock wise or counter clock wise.
Remove drain pump filter and clean it, some hair pins, cotton buds or coins or any small item that coz of clog up.
if your washing machine dont have drain pump ,but fully automatic check the drain motor if running or not? how? open the back cover for top loader washing machine only, select spin cycle and press start to see the drain motor running? the drain motor is like a small box with small wire to pull the lever of the drain to remove water inside, if the motor running or pull the lever of the water pipe but water still inside the washing machine, remove the drain cup or cover and clean it or check if have coin or cloth inside that coz of clog or water stuck,
if the drain pump or drain motor is weak this is will cause and long time draining or totally not running the drain pump or drain motor and its cause of totally stop the cycle of washing machine in rinse time or spin time, because all fully automatic washing machine, after washing cycle the drain pump or drain motor must be on, to remove water before start the next cycle. rinse or spin cycle.
Nov 02, 2013 | Washing Machines
Washer won't spin
Good Day,
Avanti washer repair
Good Day,
Nov 01, 2013 | Washing Machines
Machine lacked about 23 minutes in cycle, it stopped with lights flashing. It will not drain, therefore cannot spin. It just beeps whenbi try to start it again.
Good Day,
Nov 01, 2013 | Whirlpool Cabrio Washing Machines
Machine stopped in mid cycle with the drain/unlocking light on. No error codes. Machine goes directly to the drain/unlocking position after start. Will not fill, spin, operate. Any ideas?
Good Day,
Nov 01, 2013 | Whirlpool WFC7500VW Washer
Won't drain and showing F 01
Good Day,
Oct 31, 2013 | Maytag EPIC MFW9700S Front Load Washer
Water does not drain automatically wahes and spin
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Mar 04, 2011 | Washing Machines
Jan 08, 2010 | Washing Machines
Washing Machines Logo
48 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
