I was running, it beeped a few times and then completely stopped. I changed the fuse and that hasn’t done anything.
Your treadmill may not be turning on due to a broken or a failed power supply or a broken power cord or a tripped circuit breaker switch a failed circuit breaker switch a bad power switch or wiring failure or a bad motor control board or failed console display screen can stop the treadmill from turning on. If the outlet is not working try to reset the house circuit breaker which is located inside of the fuse box to restore power to the outlet.
SOURCE: reebok i run treadmill stops working after 10 mins
If everything still works but no belt movement, you motor controller is more than likely shot. If replacing you want to also pay attention to the deck and belt. Sence it sut down while running, it sound it an over heating problem which is usually caused from too much friction between the walking belt and the deck(the board under it) May require lube or may need replacing.
SOURCE: Reebok treadmill
Hi James
Unplug unit remove motor shroud then plug unit back in , press start and begin walking on the belt normally and try to stall the belt to make it slip ( planting foot to stop the belt).
Be careful during this test. If the problem is in the drive belt, either the drive belt will stop when stalled or the front roller will stop when stalled.
Here is the procedure for adjusting the drive belt.
Find the motor mounts. Many motors in Icon treadmills have a main pivot joint in which a bolt runs the full length of the motor mount. This bolt will require loosening to provide maximum adjustability. Some models have a single jack bolt and others have an auto tensioner. Single jack bolts are the easiest to adjust.
Find the set bolt(s) on the motor. This is typically run through only one side of the motor mount or may be on both sides but it does not run the full length of the mounting. Loosen this bolt(s) but do not remove. Jack bolt models will have flat mounts and may contain up to four bolts.
Look for a bolt that will tension the motor. If it has this bolt, it typically runs in the same direction parallel with the drive and walking belts. If your treadmill is not equipped with this bolt, skip to Step 4. If your treadmill is equipped with this bolt (very few are) the repair will only require one person. Using 2 7/16" wrenches, make a few turns to this bolt, tighten the bolts and test your treadmill for slipping. If belt continues to slip, and if their is too much tension ( you should be able comfortably twist the drive belt 90 degrees ) then replace drive belt.
If the motor, drive belt, and front roller continue to turn when the walking belt is stalled, the problem is with the walking belt slipping on the front roller, here the procedure adjusting the walking belt.
If the walking belt slips when walked on, first remove the key and UNPLUG THE POWER CORD. Using the allen wrench, turn both rear roller bolts clockwise, 1/4 of a turn.When the walking belt is correctly tightened, you should be able to lift each side of the walking belt 3 to 4 inches off the walking platform. Be careful to keep the walking belt
centered. Plug in the power cord, insert the key and carefully
walk on the treadmill for a few minutes. Repeat until the walking belt is properly tightened
If the drive belt continues to turn but the front roller stalls, you may have a broken front roller pulley. If this is the problem, you will notice it because the plastic will usually make a loud squealing sound on the metal front roller. The front roller assembly will need to be replaced and the drive belt must be replaced also. We suggest replacing the drive belt as well because it is a low cost item and will most likely, have suffered unusual wear from the problem. Another possibility is that the drive belt has worn down. In some cases, belt dressing may help correct the problem. If not, the drive belt must be replaced.
SOURCE: How do I oil my Reebok i-run treadmill?
I have a problem with my reebok i walk i run treadmill. The belt does not move on the lower speeds and after using it there is a burning smell even though it is working fine once I get past the first two speeds. I have had it 2 years but have never oiled it as I am not sure how and where.
SOURCE: How do I turn off the "finished" signal? It beeps
To turn the cycle completion signal do the following:
1. Press and hold the right "Cancel Drain" button then press and hold the On/Off button
2. When the light on the "Cancel Drain button you are pressing illuminates and the tone begins to sound release both buttons
3. Press the right-most "Cancel Drain button until the tone is either at the desired volume or silent
4. Press the On/Off button again to confirm/set desired volume
Hope this helps.
BElectric
If your problem has been solved, please be generous and award this solution 4 thumbs-up. This service has been provided FREE - your simple acknowledgement is appreciated. Thanks.
SOURCE: treadmill model 909 made by
surely there is some problem in the belt.
One of the ways to extend the life of your
treadmill is to keep it clean and dust-free. Dirt and dust build-up,
especially between the belt and the deck of your treadmill can cause
excessive belt-deck friction. This in turn, can damage your electronics
and even your motor.
You
can check for excessive belt-deck friction by setting your treadmill
around 4 MPH and walking on it. Press the stop button (or pull the
emergency stop switch). You should have to take a few steps before the
belt stops - if it stops suddenly there is probably a high friction
problem.
Excessive
belt-deck friction can also cause motor to stall or sound labored so
again, keep your belt and deck free from dust and dirct and look out if this is a problem
