Question about Fagor Washing Machines
Source electricity is good
SOURCE: servis washing machine fills but wont turn
is it a brush motor? if so the brushes may be worn, secondly the motor control pcb may have blown. also check the wiring.
Posted on Mar 18, 2009
SOURCE: Control locked light is on, machine is currently inoperable.
Push and hold the end of cycle button for 3 sec to lock or unlock control panel. here is the manual if you need.
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0606218.pdf
Good luck and please rate FixYa!
Posted on Apr 13, 2009
SOURCE: LG wash machine # wm 2277 hb front loader display flashes LE wont
We had the OE message come up and did the above procedures...that didn't fix it. I removed the dual pump modules (they come off in one piece...one is the recirculating pump, the other is the drain pump). Turns out, the drain pump impeller design sucks. Even though it turned when I put power to the pump, that doesn't mean your pump isn't bad. Once it is under load pumping water, the impeller can slip where the pin connects to it from the motor. We replaced the motor for $60 and that fixed the problem. Our unit is at least three years old and we have a family of four, so it does get used quite often. Nobody told us about the filter at the bottom of the unit and I figure if we knew this ahead of time, we probably could have avoided the impeller issue...but it is still a sub-par designed motor/impeller. The new one I ordered looks like an updated design so I don't see this happening again. It is quite easy to remove and replace the pump, btw.
Posted on Feb 21, 2010
SOURCE: WIRING DIAGRAM FOR A FRONT LOADER WASHING MACHINE
Diagram of internal wiring of ariston AV41washing machine
Posted on Mar 20, 2011
SOURCE: Candy Grand 1600 AAA class
Hello
& Welcome to FixYa You
can start with cleaning the drain filter pump assembly located inside the front
bottom panel of the washer. After it's cleaned and the problem is back then
replacing the control board is recommended repair. Please get back to me if you
have any other questions. Kevin
Posted on Jun 19, 2011
