Element was burnt in half. Replaced it. Still doesn't heat. runs well otherwise... No drying either
This Whirlpool dishwasher uses 2 sensors. For the water and drying dishes. It’s possible for the sensor to malfunction but not heating element. Try a cycle that doesn’t use the sensors if possible. Example normal wash or light wash. These cycles use a timer and sensors are bi-passed
There is always the possibility that the replacement heating element is defective.
SOURCE: dryer still wont heat
you could remove and bench test the theromostat. my kenmore would not complete the circut to heat at all with a faulty thermostat. Just use a jumper wire to bypass it and test it THERE WILL BE NO SHUT OFF COULD HEAT UP TOO MUCH IF LEFT RUNNING.
SOURCE: No heat not drying clothes
for safety reasons it has its own fuse and that may be your issue (new fuse $5)
To be safe i'd also get new thermostat ($15)
SOURCE: my Whirlpool duet dryer is getting too hot
YOU NEED A NEW THRMO KIT
STEVE'S APPLIANCE
516-300-3249
SOURCE: AMANA dryer model ALE643RBW burnt wire
I would think that:
Low voltage. A lack of proper voltage increases the current flow (amps) and can cause overheating, thus, a burnt wire. Remember, the lower the voltage, the higher the amps.
Bad connection. Poor connections can cause small amounts of arcing, thus burning the connection. This adds resistance to the circuit which causes a possible voltage drop and, again overheating due to higher amps.
Since all that equipment is on the same circuit, I would really think it is a voltage drop situation. With everything calling for power at the same time, the breaker trips. In some cases, it may be just enough for the breaker not to trip but still have a low voltage situation.
There is the possibility of an over current, such as a power spike from the power company but it would have to happen more than just a time or two.
And the outside chance that lighting got into the system when it struck something close to you home but it, in almost every case, would destroy something else, usually electronic. (This has happened to me. Trashed my dryer, dishwasher, and answering machine.)
Good luck and hope this helps. Le me know how you come out.
SOURCE: Heating Element Won't Turn Off
Ok, this is a control fault that may be corrected by shutting the power off for 5 minutes. this will reset the chip set on the control board. plug the unit back into the socket after the 5 minute ait and check to see if the element is still on. If so, replace the control board.
This is a Whirlpool dishwasher
