Question about Xerox Phaser Office Equipment & Supplies
Is there any way to reset transfer unit in xerox 6180 MFP?
Posted by Diaa Bekheet on
Ngoro
    Top Expert:
  • Xerox Master
  • 2,935 Answers
Posted on Jan 05, 2021
Testimonial: "Thanks a lot but I can't reach to reset transfer unit from service mode"
  • 1 more comment
  • Diaa Bekheet
    Diaa Bekheet Jan 05, 2021
  • vojibe5065
    vojibe5065 Jan 18, 2021
    I get paid more than $120 to $130 per hour for working online. I heard about this job 3 months ago and after joining this i have earned easily $15k from this without having online working skills. This is what I do Copy blow site..... >http://bit.do/fMAHi
  • WATCHING YOU Jan 18, 2021
    vojibe5065 is a spamming loser here at fixya
Connect 6180 MFP scanner to Toshiba laptop
Press the document to be scanned on the Platen glass. Press the Scan button, an Utility will appear. Select required size and resolution. Upon scanning document, save it in compatible format and attach it to email.
Jan 08, 2014 | Xerox Phaser 6180 MFP/N Letter-Size Color...
We can find any information for the transfer roller for the Phaser 6180, 6280 keeps coming up. Is our machine obsolete?
No, your machine is not obsolete. You're probably not finding anything on the transfer roller because it is really part of the transfer unit (part# 675K47088 ) The transfer unit contains the transfer belt and roller. Here is a video that shows you how to replace it.
Apr 28, 2011 | Xerox Phaser 6180N Laser Printer
Xerox Phaser 6180 MFP-D password
The default password is "00000" If this password does not work you can follow the following to reset it:
  1. Power OFF the machine using the power switch located on the right side of the machine, toward the back. Press the power switch to the (O) position.
  2. Press and hold the [OK] button on the Control Panel.
  3. Continue to hold the [OK] button and power ON the machine. Keep the [OK] button held down until the Ready screen is displayed. The password is now reset to the default Control Panel password, which is 00000.
    NOTE: There will be no confirmation message during or after the machine's power on sequence. However, if the procedure was performed correctly, the password has been reset.
Mar 09, 2011 | Xerox 6180MFP/D Printer
I have a Xerox Phaser 6180 MFP, and it keeps saying paper jam and there is no jam, what can I do?
Check the fuser for paper stuck in it.
Check that the 'paper out' sensor arm (in the fuser) is not broken. If it IS broken, you'll need a new fuser.
Sep 03, 2010 | Xerox Phaser 6110 Laser Printer
My phaser 6180 transfer life repalce soon what is
If your Xerox Phaser 6180, 6180mfp, 6280, or 6280mfp is displaying "Replace Transfer Unit" or "Ready transfer Unit Life" you most likely need to replace the transfer unit.
For the 6180 and 6180mfp the part number is 675K47088. For the 6280 and 6280mfp the part number is 675K70583.Here is a video that shows you how to replace this part. It is very easy and requires no tools.
Mar 30, 2010 | Xerox Phaser 6180N Laser Printer
Xerox 6180 MFP N error 016-782 Windows 7 x64
did you get a solution to this problem. i have the exact same situation.
Feb 16, 2010 | Xerox Phaser 6180N Laser Printer
Transfer Life Low Error on Xerox Phaser 6180
That error is caused when your transfer roller is out of life.
The transfer roller should be in front of the machine when you open the front cover. It will look like film material it is held with two plastic locks one on the right and on the left .
They maybe be colored yellow or blue sometimes.
(800)367-4836 <-company sells refurb and brand new ones. hope this helps. They will also give you free tech support.
Dec 23, 2009 | Xerox Phaser 6180N Laser Printer
Xerox 6180 MFP port set up problem
I have the solution. I own a Xerox 6180 MFP, and I could not send over port 25. My ISP said they weren't blocking port 25, and my web server wasn't supposed to be blocking port 25, but something in EXIM (that has something to do with email) was blocking it, WHICH CAUSED THE PROBLEM. The solution is:
For your SMTP login name and password don't enter your email address's u/p. Instead enter your website's cPanel (or whatever) u/p. For me it's the same u/p I use to log into www.yadayada.com/controlpanel to control my website. THEN choose "SMTP AUTH (Login)" as the 'email send authentication' type.
I'm still using ports 25 and 110. And I still am entering my SMTP server address as whatever I use (mail.yadayada.com). The only thing I'm really changing is the above. Other than that, follow Xerox's instructions to do it over port 25.
Oh. And for your POP3 server address, in case you don't know, don't enter mail.yadayada.com. For some reason you gotta just enter yadayada.com here (where 'yada' is your domain).
Jan 23, 2009 | Xerox Office Equipment & Supplies
Open Questions:
46 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
