www.elab.ph/forum/index.php?topic=41147.0;wap
sharp 21v-fk200m flat screen crt. Pages: (1/4) > >>. bobet20: pahelp po mga master,may problema ako malaki,,,sunog po resistor sa power supply r704,,syaka
Feb 17, 2015 - Question about Sharp Standard (CRT) Televisions .... What is the valueof resistor R704 in SHARP TV model 21V-FK200M circuit diagram.
Sharp value 2 watt resistor Standard (CRT) Televisions ...
www.fixya.com > ... > value 2 watt resistor > Standard (CRT) Televisions
value of r707 sharp model #27c241 R707 is 27 ohm 1/2 watt carbon resistor,if you ... What is the value of resistor R704 in SHARP TV model 21V-FK200M circuit ..
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Schematic diagrams of some popular model TVs and other devices are given. Hope it might help you to find out the LOT number.
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
you should have a factory reset option in the main menu _ using the remote to access menu and proceed to "setup" or "system" once in there just do a simple factory reset then so a simple system set up
1) test the power supply: line cord, fuse, c.breaker, rectifier, switch, filter. 2) horizontal output +125vdc( HV transformer or flyback, +HV rectifier) 3) all other circuite +12vdc 4) vertical output +80vdc see the b.diagram attached. God bless you
Or even a cheap replacement laptop power supply as these usually start at 1000 mA which will give you current to spare and have a longer lifetime. most of these cover from 15V to 24V and are either auto switching or manual select for the voltage. Plus you can pick these up from most electronic / big box / supermarket shelves
