Can anyone help with walkthrough on how to check gravity drain lines and make sure they are working properly/clear?
SOURCE: Kithcenaid Superba KSRS25QDWH01
If you pop the front cover off the ice maker you will find a screw with a plus and minus on it. Adjust it and that will cut the water fill down and should solve the overfill problem.If the ice is not dumping spray the tray with Pam and that should solve the dump problem.
SOURCE: Whirlpool Side by Side Ice Maker Not Making Ice
If you have the type of ice maker that has an ice bin on the freezer door, then there are instructions available at www.AnyoneCanFixIt.com to fix the ice maker problem. They also sell the part that is sometimes required to repair this common problem on the ice maker. The problem is notorious on these refrigerators that were made around 2004 and later. The ice maker will usually go out within 1-2 years. They have redesigned a part to eliminate the problem.
SOURCE: Water runing down back side of icemaker and forming icicle.
If it is running down the back of the icmeaker then you need to make sure the inlet tube is properly installed into the fill cup on the icemaker. If the tube is in the right place then your icemaker fill level needs to be adjusted.
SOURCE: Thin Ice on Whirpool Ice Maker
Hi
If
The ice maker has completely stopped producing ice
Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
The ice maker is producing ice poorly
When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
Please do rate the solution as "FixYa" if found useful and revert for further assistance.
Thanks
Rylee
SOURCE: Ice-o-matic wont' drain water from bin
the purge valve empties the tray... the bin just drains with gravity... If you bin isn't draining... it must be clogged somewhere.
