Dr Pawan is best Gastroenterologist in India . He has experience of 15 years. He specialize in all kind of luminal, hepatic, pancreatic, biliary and systemic diseases.
Dr Mayank Agarwal is a MD MD Gastroenterologist, Liver and Pancreas Specialist
TREATMENTS
UGI Endoscopy
Esophagogastroduodenoscopy, also called by various other names, is a diagnostic endoscopic procedure that visualizes the upper part ...
Polypectomy
Polypectomy is a minimally invasive procedure in which doctors remove abnormal growths of tissue, called polyps, from inside your ...
Variceal Banding
Variceal banding is a procedure that uses elastic bands to treat enlarged veins, or varices, in the esophagus.
Hemorrhoidal Banding
Hemorrhoids are pockets of swollen blood vessels inside the body. While they can be uncomfortable...
ERCP
Endoscopic retrograde cholangiopancreatography is a technique that combines...
Endoscopic Ultrasound
Endoscopic ultrasound or echo-endoscopy is a medical procedure in which endoscopy is combined...
For More Information Click here
https://apolloclinicguwahati.com/consultations/gastroenterology/
Dr Mayank Agarwal is a MD MD Gasteroloenterologist, he is a Gastro, Liver and Pancreas Specialist
Services
1. OPD consultation for the above mentioned problems
2. Upper GI endoscopy
3. colonoscopy
4. Sigmoidoscopy
5. Biopsy of suspicious endoscopic lesions
6. EVL Banding
7. Polypectomy
8. Esophageal structure dilatation
9. Esophageal stenting for cancer
10. ERCP for CBD stone
11. EUS
For appointment you can call him at 9085612000 or visit apolloclinicguwahati.com
Apollo Clinic, Kanchan Road, Opp Bora Service, Ulubari, Guwahati - 781007
just take it back to the place of purchase im sure there will be some sort of assistance available it should be still under warranty
if you want you could have a look through all of you devices to make sure the all drivers are installed for these devices
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
if you need more help with this post a reply
which country is Guwahati in
hope it helps
