Question about Toshiba Televison & Video
I can put a flashlight to the screen and see the picture. It does my shut off the picture goes dark the on green light stays on
SOURCE: Sony kdfe60a20 - The TV turns on but after a
classic Sony telling you the lamp is going bad. Replace lamp yourself it is consumer replacable.
Posted on Aug 11, 2009
SOURCE: nintendo DS lite power light comes on but both screens stay dark?
my son ds the power light comes on but both off the screens are dark and i dont know what happen
Posted on Aug 26, 2009
SOURCE: ACER AL1914 LCD Monitor goes black but green light stays on
The monitor is doing a self test a finding an error.
The lcd has three parts, the screen plate(windows)/the logic(vga)/the
inverter(power plug). Parts that go are the backlight ccfl's, behind
the plate, and parts of the inverter, ie capacitors, all three take a
bit of power from the inverter. The self test check that all the lights
are ok and the inverter is ok, else it switchs off, ie if 3/4 light
work it will switch off(my own case), hence the on chech error then
off, However sometime there are stages of on/off ie on/ but no screen
display, if that is the case the following may be of help...if you put
bright light at an angle close to lcd can you see a windows shadow,
text icons etc, ie still logic power passing,then .... (from a.n.
other) after two weeks searching I finally find doctor living stone
http://www.aplusperfect.com/articles/lcd_capacitor_repair more fun with
paulbtorrent
the takening the case bit off is like opening your wallet a second time
after buying a new LCD, but you must! smallest two screw driver's flat
headed, practice using two pennies stuck together()with your fingers
after, one little () move and inch and {} again, with the case , it
does not break, just need to lever open
[once open you realize they somehow put that old briefcase clip
inside!] also note the bright light test to do first to see if can see
a windows screen , and that capacitors are one for a number of things
that a make a inverter work! there a transistors as well, given that
however, to replace all the capacitors on my inverter, was 11
capacitors, cost me $11 (uk ebay) and already had the iron and solder.
So only cost me me $11 to try and see but no luck , still fun and I
still can see the screen for 2 sec' at a time plus I have a spare set
of caps now in the event that the new one do go burst! you have to
laugh really, what next , a new on/off button, as you work though the
whole inverter mmmMMMMmmmMMMMmmmMMMMTim
Berners-leeMMMMMmmmmMMMMMmmmmcome back all is not
wellMMMMMMMMMMnnnnnnweek later land sight
mmmmmMMMMMMMMMmmmmgggggggg(from
another a.n other)Generally, if the screen went out quickly, it was the
inverter. If it went out over a slow period of time (flickering etc..)
I would bet it is the lamp.replaceing the lamp should be pretty
challenging. as that requires complete breakdown of your LCD,
extraction of your dead lamp, and soldering in your new lamp... but I
would like to say that I it did this after realizing it's 2 x kitchen
strips inside [========] with wires that can connect back to the
inverter with out any desoldering(ie kit assembly/dis) with the outter
case remove (glass plate safe away) I could reconnect and see that 3/4
were working (i!i hardcard ) cause the inverter to switch off after a
secound ! order bult and replace and going
to cheap and see if I can get away with fitting a 15" in my 19' as it a
1/3 of the price ! the market as drop out there, hope the inverter does
not miss the length, or the screen out
put.http://www.lcdparts.net/howto/troubleshooting/LaptopCCFL1.aspx OR
MONITOR
Posted on Feb 08, 2010
SOURCE: picture goes on and off every few minutes
Your lamp is failing, it needs replaced. The part number for it if A-1085-447-A. Try google to locate a vendor. I hope this was of assistance, best wishes.
Posted on Apr 23, 2010
