SOURCE: lakewood 7096 heater
Some of the newer models have a thermal fuse which may be blown. It doesn't look like a normal fuse at all. It is similar to a transistor in looks and should have continuity from one end to the other. It will be tied in to the incoming power cord inside the heater, and may be covered with rubber coating within the wire. It will look different when you notice it. Sometimes its too far down inside where the heat causes it to blow prematurely. The purpose is to cut the power to the unit in case it overheats. You can get one at radio shack for less than a couple of bucks. The older models don't normally have one, but I would suggest you put one in it if that's the case.
SOURCE: Where can I buy a
I will advice you get the unit needed at either ebay.com or amazon.com.
Take care.
