Question about JBL Audio Players & Recorders
Finding why my JBL CS300.1 amp.keeps.blowing fuses
Posted by Josh M Giaimis on
  • JBL Master
  • 18,859 Answers
The process involved in troubleshooting and repairing that amp requires specialized tools and meters. You would need to check all the capacitors to see if they are okay by using ESR and capacitance meters, To check the semiconductors you need to unsolder at least one leg and check them unless they are integrated multistaged devices. IF they are you need to check their current draw.
Posted on Jan 01, 2021
Testimonial: "great info so i connected low amp 12 volt power not blowing fuse but all 3 lights are blinking blue on top"
  • Brad Brown Jan 06, 2021
    Those lights are flashing because the power supply cannot provide enough voltage to the unit. There is something in that AMP that is pulling so much current the voltage on your power supply is dropping before the fuse blows. I would wager that you have a bad MOSFET
Why does my inline fuses keep blowing on a jbl gto 14001 amp
You need to calculate the amount of amps being driven through that fuse + the amount you need to feed the amplifier.
In my Volvo S40 and V70 I had no problems driving an amplifier of the rear power connector, but on my Honda S2000 however I had to create a different connection all the way to the battery line for a smaller amp (connection as in cables, condensers/filters and fuses).
JBL subwoofer not giving sounds even it is correctly connected
If this is a powered sub, than it will have it's own power supply and small mono amp, both of which can fail. Could be a fuse, but if the fuse blows again you will have a short on the main amp board.
Jbl subwoofer fuse
there is a short in the amp that would need to be fixed before the unit will power on
Still Blowing fuses
there could be something wrong with moisture. I had a drink spilled down the back of mine and I had to clean the board cause it kept blowing fuses.
Aug 18, 2017 • JBL EON 515
2helpful
2answers
My jbl pb 10 has a noise and it burn the fuse... changing the fuse it burn the fuse again..so it might have som other defective part that is causin the noise and the fuse burning... any sugestion?
It blows the fuse because a semiconductor device has developed a short (in otherwords acting like it was just a piece of wire). Because of the noise I would suspect the main amp device is the cause. It will be most likely on a heatsink.
The fuse keeps blowing as soon as i power up jbl pb 12
You have an overload in the power supply or main amp of the subwoofer, often caused by short circuited transistor. Check this out by putting an ohm meter probe to each of it's legs. If it acts like you were touching the probes together you have found a guilty part.
1helpful
Need Specific Specs on JBL 350.1 Mono Amp
Keep in mind the input current to the amp is not continuous. Yes, the fuses on the 3501 are rated at 2x30A, but that means that at any one time, if the peak current goes above 60A, (theoretically) a fuse should blow. But in reality, the amp will draw much less current than that under normal operation. Even by adding the 300/4 to the mix, in my opinion, you will be ok.
2helpful
2answers
JBL Eon 15 Blown Fuse
These fuses are most likely 3 Amp fuses. Please note that if the replacements blow as well, that there is a problem within the amp section that will require repair.
Dan
2answers
JBL PSW-D112 Speaker fuse blow immediately after replaced
The fuse is designed to protect the circuit and prevent fire. When a fuse blows it is because it is getting to much current through it.
In some cases it could be because you replaced the fuse with one that did not meet the specs of the required fuse, there are different types of fuses and you should always replace with exactly the same type of fuse.
Do not replace with a higher Amp fuse, you could end up frying the amp at least. It's not a safe thing to do since there is an off chance of fire from using the wrong fuse.
If you have the right type of fuse installed and it is still blowing, then refer the unit to a qualified service center for repair, or look for a new replacement Amp.
john
Top JBL Audio Players & Recorders Experts
 Grubhead
Grubhead
Joaquim Martins
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
