Cameras Logo
Question about Nikon Cameras
I need to factory reset my camera. I go to settings and check everything but there's nothing there about reset settings or anything reset I have a Nikon coolpix L840. How do I do a hard reset there's no buttons with green buttons next to them
Posted by Naomi Sirois on
RandomJae
    Problem Solver:
  • 7 Answers
  • Press [Menu] button
  • Press the [</ dial left] button to move to the tab
  • Select "Setup" by using [?/ dial down] button and press ok
  • Scroll down and highlight the "Reset All" and then press ok button
  • and if it still doesnt work then hold the power button for a minute and then run it on
Posted on Dec 30, 2020
  • Naomi Sirois
    Naomi Sirois Dec 30, 2020
    There's no option to reset. Just says conformity marking and firmware version
5 Related Answers
Anonymous
SOURCE: Nikon CoolPix Flash Problem
This happened to me too!
Turn the dial to setup, push the menu button & select reset all. This will restore the defaults & let you use the flash again.
Posted on Mar 21, 2008
Anonymous
  • 744 Answers
SOURCE: flash on Nikon Coolpix s200 camera not working
hi try to reset ur camera...To do such reset, turn on the camera and hold the menu button down for longer than 5 seconds. A message should hopefully come up on your LCD asking if you want to reset the camera. Select Yes...
thank u!!!
rate me!!
Posted on Jun 28, 2009
Anonymous
  • 11967 Answers
SOURCE: Mac doesn't recognize my Nikon Coolpix
Use a cardreader to download your pictures. Download them to a folder you create on your desktop. From there, you can do anything you want with them.
Posted on Aug 13, 2009
Anonymous
SOURCE: Nikon D50 - clock and battery icons blinking
Hi
I had the same problem and rectified it by going to Nikons website , follow this link for the answer:
http://nikoneurope-en.custhelp.com/app/answers/detail/a_id/10601/p/19%2C244/c/241/kw/Clock/r_id/127673
Posted on Mar 26, 2010
  • 102366 Answers
SOURCE: nikon coolpix p90 how to reset to factory settings
It doesn't reset everything, but there is a "Reset All" command in the Setup menu. Press the MENU button, then the wrench and then "Reset All."
This reset leaves the date/time, white balance, language, and video mode alone.
Posted on Feb 17, 2012
How to reset frequency dvr h 264?
I am assuming you will need a system maintenance procedure to reset everything to factory default setting. See section 3.7.5 in this manual.
http://www.monopricehub.com/files/manuals/9888_manual_121229.pdf
Factory reset
In camera settings menu, on the bottom of the screen you find Settings. In Settings is the only reset the camera knows. You only will reset the menus and shooting options. Date, time, language and video output settings are not reset.
If your camera has serious trouble, accessing menus or something like that, there is nothing like pressing a button for several seconds and everything will be ok. (not in the manual)
Reset factory setting
Although Nikon cameras can be set back to the factory settings in several steps, I can't find anything in the Canon manuals, that says how to reset the camera or to put it back in the factory settings.
Perhaps you did change the firmware once. Most of the time there is a descriptions, how to do that and what to do if things go wrong. This could be something to reset the camera.
We have a KDL-26U2000, the problem is the menu button doesn't bring up the menu?? When you press the button on the remote or the top of the tv the green light will flash so the tv must recognise that I'm...
Checking your remote can be done with any digital camera since they can 'see' the infrared light from them but I suspect the remote is working; generally, if they are emitting anything, it will be sending correct correct pulse trains.
Having the camera 'live' you will be able to see that the remote is working by aiming the remote at the camera's lens and pressing any button while watching the camera's LCD display. The output of the remote will appear as white or near white blinking lights.
> I've tried to reset to factory settings but when I've got into the service menu I can't input anything?
Often the service settings require entering some code (password) sequence to access factory settings and it may not be possible to enter the code if one or the other end of the IR system isn't functioning.
Summary; I think the remote transmitter is OK but the receiver in the set is not decoding the received signal despite it indicating that something was received.
I think the set itself is a fault and you will need a tech on site on in the shop to search for the right board to replace since the IR receiver may be part of the main board (expensive) or a separate assembly (somewhat less expensive).
Hi, I am trying to reset my acer desktop to factory settings. I have tried the acer erecovery management restore and nothing happened. I have also hit delete at startup and clicked "restore default...
You can download the windows installation from the Microsoft website, and run it. Select the Custom Install option to run a Clean Install and select to Reformat the drive, this would clean the drive and reinstall windows, which would reset everything to the factory settings.
That's an alternate route to go if the recovery software on your computer is not functioning properly.
Hope this helps!
Master Reset Olympus x840
To reset the camera - have the camera in shooting mode - go to Menu - left arrow to reset - press ok - Highlight yes and press ok. This will set the camera back to factory default settings. Hopefully this should solve the issue.
2answers
Gphone Error
Maybe you can try to reset the phone back to factory settings (you'll lose all your data!!): 'Home' > 'Settings' > 'SD card & phone storage,' then select 'Factory data reset.'
Playback Issue!
If the drum is noisy when moving the camera around.The drum assy is faulty,needs replacing
Top Nikon Cameras Experts
Steve
David Shaub
Are you a Nikon Camera Expert? Answer questions, earn points and help others
