Toys Logo
Tim Webb Posted on Dec 29, 2020
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
K31 B79801 mr christmas carousel. Why did it stop turning?
Require instruction on how to get inside to check parts.
ADMIN Andrew
Level 3:
Top Expert:
  • Toys Master 66,758 Answers
  • Posted on Dec 30, 2020
ADMIN Andrew
Toys Master
Level 3:
Top Expert:
Answers
66758
Questions
Helped
5045906
Points
378655
They stop working because they are made in China for $5. They are not normally repairable apart from changing batteries. If you want to get inside, it will be through the base. Probably screws hidden under felt.
https://www.ebay.ca/b/Mr-Christmas-Carousel/908/bn_55191126
Testimonial: "My testimonial is to thank the person who supplied answer no.8 "Mr Christmas double decker carousel rotation stopped." My carousel though a different model was put together in almost exactly the same way and so allowed me to get inside. Many thanks One inside the problem was the DC output from the pcb to the motor had failed. The solution was to buy and fit a second jack plug and socket and use a spare mobile phone charger with a 6vdc output to drive the motor. Everything now works fine. Many thanks to fixya and the experts who contribute their knowledge."
  • ADMIN Andrew
    ADMIN Andrew Jan 23, 2021
    Excellent news. Answer Number 8, was a 'Suggested Answer' from another post that was similar. Thanks for the feedback which does help others in the future.
Lemax Grand Carousel stops turning, everything else works. Do you have link for disassembly?
Lemax provide ZERO support to their products once they are discontinued exactly 12 months after release date. You use them perhaps a month maximum and then put them away, so basically, the warranty is 1 month!.
There some good third party videos though and one company does generic Chinese parts
Lemax grand Carousel model# 84349 belt
Happy Holidays Parts https://www.happyholidaysparts.com > product-page > le...
- OUR COMPANY HAS PUT TOGETHER A BELT REPLACEMENT REPAIR KIT. KIT INCLUDES ONE BELT. Tip: To get to the gear box remove peak cap and remove two screws. Then ...
US$13.46 · ‎In stock
mr.christmas, dept 56, lemax , trendmasters parts and repair
Happy Holidays Parts https://www.happyholidaysparts.com > lemax
... Dept 56, Lemax , Trendmasters parts and repair, we supply ... Lemax grand Carousel model# 84349 motor kit. Price$28.95. Free Shipping$40 and ....
Jan 02, 2024 • The Toys
tip
How to fix a Mr.Christmas Carousel swing and dis assembly
Mr.Christmas does not offer ANY tech support or dis-assembly diagrams. Once you purchase it, that's it. But......you can try this: The carousel consists of an outer roof which snaps around an inner roof (where the horse poles insert; there are four tabs that keep it attached to the outer roof). Outer roof removal; You need to carefully remove the "crown" (which is glued on) You may be able to use a blow drier on the hot setting to soften the glue,but not too hot to overheat any parts. Twist and pull gently and carefully remove the crown. Once the crown is removed, you'll should see a screw. Remove the screw to remove the outer roof.
Make notes of screws and parts from where they came from and where the components are located. Once the roof is removed, you should see the light circuit and connection pad. You will need to unsolder two wires from the wipers,taking care not to loose the springs.You can now unscrew the nut which holds the light contact bracket in place. Take care in removing this piece., then unscrew the contact board while pulling it over the central shaft. You should now be able to remove the inner roof, and you can lift up the main assembly.
You now are at the base and several screws holding the motor and central shaft to the plastic base. This will come free but will remain wired to the switches. This carousel is driven by a bunch of rubber bands,and If there is no rubber band connecting the shaft to the drive motor,than you have found the problem. If you find that the motor does not function or work, you can check the wiring that runs from the switch to the motor for a bad connection or break in the connection. To reassemble, just reverse the previous instructions. You may have to rotate the roof to allow it to fall into place, it should only go on one way.
on Feb 19, 2010 • Toys
1helpful
Why is my Mr. Christmas Double decker carousel sticking while turning
It's not spinning, what do I do? Check rotary blade / turbine and make sure that each blade is angled and there is space in between blades to let the air through.
Mr. Christmas carousel squeaks after running for an hour. Is there a way to lubricate it?
Try to lubricate it by using lubricants or baby oil, it can also with vegetable oil. Lubricate the problematic parts, maybe the mechanical parts.
Mr christmas carousel lights above each horse won't turn on
i would check any bulbs it might have some times it only takes one to blow to stop the others working.not saying this is what is going on with yours .
MR. CHRISTMAS CAROUSEL WON'T TURN
I realize this post is way old, but wanted to thank LtJim for his description on how to take it apart.
It turns out the reason mine was not spinning is that one of the plastic mechanisms that make the horses go up and down (located under the main piece that comes off with LtJim's directions) had partially broken and that horse would go all the way to the bottom and then the carousel would stop spinning.. There was no way to fix the plastic, but by holding the horse up with zip ties hidden under the top got the thing to work again. Thanks again!
Dec 12, 2012 • Toys
2answers
We have a Gemmy airblown carousel with four figures inside. It will only partially inflate. We have unzipped everything and untwisted everything. The bottom inflates and part of the top but nothing in...
mine is doing the same it gets twisted cutting off the air supply. I unwind it and lubed it but it continues to happen. there seems to be some sort of spring on the inside at the based. i'm thinking of cutting the tie straps and seeing whats inside...
14helpful
8answers
Mr christmas double decker carousel rotation stopped.
These things are really hit or miss. The company (Mr. Christmas) is virtually useless in the realm of tech support. Caveat Emptor and all that. Personally I have no use for this sort of thing but I must admit they ARE cute (when they work)!
I met a gentleman at the Citigroup Station Model Train exhibit (where I work as a train operator during the holidays) who had a problem similar to yours (in his case it's the music which doesn't work). I offered to attempt to fix this fellow's Mr. Christmas carousel (which he bought used, strike one!). Being a model railroader, I have vast experience repairing model trains but thought this might be a challenge. I did some online research and came to the same conclusion you did (ie Mr Christmas doesn't give a *%&^ once you've bought something, and there's NO viable tech support or schematics to be found). I was nearly about to throw in the towel and return it when I figured out how to open it. I will at least get you to the innards.
My guess is that these carousels are more or less mechanically similar (this fellow has the Disney Carousel, model 94448). The carousel consists of an outer "roof" which snaps around an inner roof (where the horsie poles insert; there are four little tabs which keep it attached to the outer roof). To get the outer roof off, however, you need to carefully remove the "crown" (which is glued on with some sort of silicone based adhesive) It is glued on with some sort of silicone based glue. BE CAREFUL removing it! Once the crown is off, you'll see a screw. Unscrewing it allows you to remove the outer roof.
If you feel mechanically adept enough, continue but TAKE NOTES as there are a LOT of screws and parts from here to the bottom base (where the motor and electronics are located). Once the roof is off, you will see the light wipers and contact pad. You will need to unsolder the two wires from the sprung wipers (be careful not to lose the springs!). You can now unscrew the hexagonal nut which holds the light wiper bracket/wipers in place. CAREFULLY remove this piece! You will now need to unscrew the contact board. pull it over the central shaft. You can now remove the inner roof. Once the inner roof is removed, you can lift up the main assembly (ie the horses, &c); CAREFULLY place this aside!
You are now at the base. There are several screws holding the motor and central shaft to the plastic base. This will come free but will remain wired to the switches. FYI the whole mess is a rubber band drive (sort of like an old cassette player or VCR). If there is no rubber band connecting the motor to the shaft, that is your problem! If the motor plain doesn't work, check the wiring fro the motor to the switch!
To reassemble, just reverse the directions. HINT: the roof will only go on top of the mechanism one way, so if it doesn't quite fit just rotate the roof until it does! Good luck!
Dec 27, 2008 • Toys
3answers
Need light bulb for Gemmy 6ft inflatable carousel
Go to the website holidayinflatables.com or buyinflatables.com they carry parts for inflatables.
Top Toys Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Toy Expert? Answer questions, earn points and help others
