SOURCE: Hotpoint Aquarius WD64 - Tripping the electric?!
something is going down to earth, start by unplugging the motor and retesting, if it doesn't trip them check the motor carbons etc, if it trips then check the heater element for contact down to earth, replace if needed etc, then check the outlet pump the same way if i have helped rate me please ps when working on machine remove from power supply
SOURCE: My Bosch Classixx 1200 washer causes the household RCD to trip
The first thing I would recommend u do is to remove the motor and check the carbons for wear, Their should be at least 3mm of carbon showing, any less then u shud replace.
The other possibility is a faulty heater element, u cud try it with the element disconnected, if it does not trip then the element is faulty.
Plz rate my solution.
thanks.
SOURCE: 2000 Elantra manual trans car won't crank
While the suggested resistance check of the clutch safety switch should catch a bad switch. However it may still be bad. I had the experience on my 2001 Elantra with the same problem happening intermittently. I checked and I had the delay check the switch and it looked okay. After three more trips and having them test other things including replacing the Starter motor under warranty they just replaced the switch. No more problem until 3 years later same thing started happening. I asked them to specifically check this and they just adjusted how far the switch button stuck out for teh clutch pedal to engage it under the dash. 4 days later it happened again. I said f it or something like that and went and bought the 15 dollar switch and put it in myself. I've not had a problem since then. But then I'm just coming up to the 3 yr anniversary of that switch.
You can also just bypass the switch and remember not to crank your starter without the clutch engaged unless you want to experience what whiplash is like firsthand.
Just change the switch.
SOURCE: Vax 2000 trips electrics
Try the reset drive belt brush button - you'll find it underneath the main power switch on the handle. Also check the brush isn't clogged, by the sole plate by tipping it over and undoing the screws on the bottom place where the beater bar is.
SOURCE: Diplomat Softline ADP0300 Gas-just not cooking ...anything!
Hi there..
I Just recently had the same problem, also with a diplomat gas oven..
The problem I found was down to a small resetable component under the main cover. ..
It took me ages to find the problem and I had taken the whole electical parts of the oven to bits before 'accidentaly' coming across this 'thermal switch' (located inside the main cover, at the top, behind the display module).. - to reset this there is a tiny red button between the connectors.. press this - and it should all be fine again... : One importnat note is that this may be tripping as a consequence of the fan not running or by my thinking not running on after the oven is switched off, leaving the casing to heat up and then trip this switch component.. - if this component is faulty it can be found in RS components or Farnell components.. look for Thermal swich manual reset part no: L100C 9082 470.
