Unplug the unit and wait 2 FULL MINUTES before plugging it back in. That will reset the circuit board and you should be good to go. If it doesn't work, my bad!!!!!! -AGK
f 2 code states that oven has exccded 590 deg w/door in unlocked position or 990 f in locked . either the themp prop is bad or the relay in the EOC ( clock ) is welded closed . I would replace the prob first ( less expensive ) then the clock if needed .. **** ..
I think I got this.... my oven clock does run slow for months then perfect for months, then slow again. I believe a repair would be a waste of money since there is nothing wrong with the clock. The problem is with the supplier of electricity. The oven uses 220 so may be related to the coverting 220 to 110 v. The clock is counting cycles in the electricity supplied to your home and that varies all the time.
You'll have to remove the back of the panel in which the clock is installed to access the back of the clock. There will be two wires attached to the clock. Just pulling one of these wires off will stop the clock.
I would suggest, however, that you pull both wires off, put electrical tape on the ends of the connectors, and tuck them out of the way somewhere around the clock.
I've seen this many times on GE and some on Kenmore. There is a glitch in the clock control. It will keep time and everything else still works, but the display won't stay. This requires the clock/oven control to be replaced. For what it's worth, it's not worth it as long as nothing else is affected.
Hi!1 your control board is shorted need a new control clock board..Just remove the screws to the top back panel and you will see the the main board easy to fix..Just buy main clock board..Good luck..
This is a very strange one, and you don't say how old this unit is or how long you have had problems with it, but most likely you have a poor electrical connection. Turn the breaker off and unplug the range. Remove the cover over the receptacle you just pulled the plug from and check all the electrical connections. If all OK, check the electrical connections where the cord attaches to the range. If still OK, inspect additional range and household wiring to range, including the connections right on the circuit breaker.
