SOURCE: Model : HP LaserJet 1320
Hi, If that is the only light on (blinking or not), then you probably have a paper jam or a door open somewhere on the printer. Make sure both doors are closed securely at the back of the printer. Make sure that the toner cartridge is secured inside the printer. You not only have to just insert it, but you have to insert it until you can feel it lock into place. Make sure there is no paper jammed inside the printer or inside the rear doors. If you have a blinking light AND the power light is ON, press the GO button. This is also a sign that a complex print job was sent that max'd out the installed memory. Hope this helps!
SOURCE: I cant print from hp laserjet 1320, orange light is always on.
there is something wrong in your cartridge may be its empty.. replaced a new one
SOURCE: HP Laserjet P1008 not Printing
What you need to do is go to the printersmenu in the control panel and then see which printer is set as the default printer.If the selection is correct,see if any documents are pending in the print queue or not.If it still does not solve your concern then your printer has taken up an IP address that is no more recognized by your computer.So you need to change the port to which the computer is printing.If you want further support you can avail free technical support on http://tinyurl.com/m7ghqz.
SOURCE: Printing problem with HP laserjet 1320
I've seen this error on this model in the past. I was only able to resolve the issue by replacing the formatter board. Hope this helps.
SOURCE: hello sir.I am Dnyaneshwar,I am using Hp laserjet
Make sure the toner is not empty just remove the toner and shake it and installed it if the problem is continue then replace the toner.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
