2963
DELONGHI
CPC505 AU
5417.7 KWH
https://github.com/GosHawkTas/fridaynight/blob/master/postcodeData/3138.csv
SOURCE: Split System Air Conditioner Model
Enter the name of the unit into your browser. It will ask for a model #. Enter that. All the info you need should be displayed. (I can tell by the model# your unit is 3 ton. Rule of thumb; 10 amps/ton Therefore 6.2 KW)
Ray
SOURCE: Delonghi split system (inverta) leaking
clear drain line with air or water. If unit is really old possibly drain pan rusted with holes. make sure to change air filter this will cause coil to ice up if restricted.
SOURCE: hi need external fan blade
Hi, if you are speaking of the condenser fan motor outdoors, and you need a new prop for it, most wholesale places sale these only. But, take it off and find a appliance parts only house so they can match it up. The pitch of the blades have to be correct, and make sure you have the right rotation. The blades are made to scoop up the air and pull it through the outdoor coil. Some times you can go to a wholesale parts house and they will sell to you. I have done it in the past before I got my contractors license. Good Luck,
Shastalaker7
A/C, & Heating Contractor
