Ovens Logo
Question about Belling Ovens
We have a belling induction cooker. The trip blew now E5 is flashing on the hob, only two of the hot plates are working and neither of the ovens are working. It's only 2.5 years old.
Posted by Peter Watson on
ADMIN Andrew
    Top Expert:
  • Belling Master
  • 53,131 Answers
Unfortunately, Induction hobs on domestic cookers have always been a problem. A single, one ring catering hob is $1,200 and is expected to last 2 years in an industrial environment.
There are two videos here, but I reckon you will need a service call.
https://www.google.com/search?safe=off&rlz=1C1QJDB_enCA643CA644&sxsrf=ALeKk01r2k0Xw_ZCF69PXpLMkc_N2QzdIQ%3A1608069741109&ei=bTLZX5KRBtfRtQb9wp6IBQ&q=belling+induction+hob+e5+error+code
Posted on Dec 15, 2020
Aeg ovens work on brand new model number 49176iw-mn but induction hob wont turn on
Many people have had faulty AEG cookers. I would return it if i were you and get something else
Jun 24, 2016 • AEG Ovens
1helpful
I have a stoves cooker which was working fine until we upgraded to the seventeeth edition consumer unit and rcds. Now I have a negative earth fault.Rcd trips out, circuit is fine up to the cooker. Any...
The clue will be when the rcd trips out. If everything is switched off on the cooker with the exception of the clock when you power it up and then it trips out, it could be in the wiring to the oven from the control switch and or the wiring in the oven. The only way you are going to find this is to take the oven out of the housing and test the wiring, isolating components until you find the problem.
Where can I get a manual? Can it be downloaded? Thanks
.pdf user manuals can be obtained via [email protected] Quoting the exact model number located on the rating plate located on your appliance as detailed below.
Range Cookers
Behind the Drop Down Storage Panel beneath the oven door or on the Oven Chassis behind the door
60cm Freestanding Cookers and Ovens
On the Oven Chassis behind the door
Hobs
On the underside of the hob (any oven or hob situated underneath the hob may need to be removed to gain access.).
1helpful
Hello. I have a new hotpoint CIO644 induction hob but when I turn a hob on, and put a pan of any size on the hob, it start ticking. The ticking stops when I take the pan off. The display shows the setting...
Hi
I'm not sure that you really have a problem as with induction hobs you need to put your pan (metal only) with the ingredients in it on the hob before switching the heater on.
it is the pan which will get hot, the ticking may or may not be the pan heating up.
Try it with water only in the pan and see if it works.
11helpful
2answers
Have a new electric cooker but the oven and 1 of the hob plates isn't working dc5422 beko
hi chances are that the internal thermal cutout fuse has gone this fuse is situated on the right hand side of the cooker when you have taken the back plate off about half way down it has two wires attached to it and is screwed with a self tap on the right hand corner of the body of the cooker near the middle of the cooker. You can buy this part and have it delivered for about £6 so is a very cheap fix.
Sep 17, 2010 • Ovens
2helpful
Belling oven stopped working
It is most likely the element needs replacing although it could be the oven thermostat.
I would try a new element first, it is not a complicated job to change the element but you need to switch the power off at the wall before you start work.
If you are unsure or in doubt about carrying out the work seek professional help.
Dec 22, 2009 • Ovens
Top Belling Ovens Experts
Marvin
Marvin
Lawrence Oravetz
Gil Shultz
Are you a Belling Oven Expert? Answer questions, earn points and help others
