7.4 cubic feet
https://www.geappliances.com/search.php?search_query=GE%20dryer%20DPSQ475ET5WW%20&tab=manuals
Testimonial: "Thanks ever so much! I learned to search the geappliances.com for DPSQ475ET5, (dropped the WW ), and got this super-informative marketing guide! From https://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=972370016.PDF "GE Profile™ DPSQ475ET/GT • Super 7.0 capacity • QuickClean controls • Deluxe end-of-cycle signal""
SOURCE: Dryer Wont Start - Smells Burnt
check for shorts and something holding the fan also look at breakers
SOURCE: What capacity is our Kenmore washer & dryer?
Use the sears parts website, and you can download the manuals for both machines that will tell you.
CLICK HERE
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
SOURCE: Capacity of Kenmore Model: 110-9155120 Washer and 97566200-75662
3.6cu ft.
SOURCE: I have a GE Sensor
Could be one of 5 problems:
Thanks for using
FixYa - a 4 THUMBS rating and POSITIVE
Comment is really appreciated for
the FREE answering of your question. Capt. Spock said: "An
ancestor of mine maintained, that if you eliminate the impossible, whatever
remains, however improbable, must be the truth."
All of the above are easy do at home repairs if you re handy. You should be able to get a good idea of what is wrong just by turning the dryer drum by hand. If the problem is the front bearing or guides, you will hear a grinding noise in the front at the top of the door.
Below is a link to diagrams and parts for your dryer. - J
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5100355
Thanks for using
Capt. Spock said: "An ancestor of mine maintained, that if you eliminate the impossible, whatever remains, however improbable, must be the truth."
