SOURCE: Panasonic TH-42PD25
This is a known problem. Panasonic sells a jig to correct it. I had the same problem and bought the jig for $60. It plugs into a special port in the back of the tv behind a little door. You can read all about it here: http://www.avsforum.com/avs-vb/showthrea... if you want, contact me by replying and I can mail you the jig temporarily for $10 plus S&H. You'll save money and it worked for me, i just need it back.
SOURCE: Black and White video on S-Video output
The Concept of S-video is Splited Video Signal (Luminance for black and white, Chrominance for colors), in your case the luminance is ok but there is no chrominance out. Expert technician is required: Check for dry solder at the s-video out outlet. Good Luck Toufic Malek
SOURCE: hook up all my components together
Hi knit, You need a 4 port A/V switch. Ebay has one: http://cgi.ebay.com/4-Port-AV-Audio-Video-S-VIDEO-Selector-Switcher-w-Cable_W0QQitemZ150168531361QQihZ005QQcategoryZ73390QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
SOURCE: Video out problem
I own a DMR-ES20 and had that problem. Panasonic Customer Service gave me a fix that works.
On the unit itself, press STOP and PLAY at the same time for about 10 seconds. This fixed my player.
SOURCE: LG RU-42PX11 42 plasma TV has black bar
it seems to be a bad connection somewhere but I disconnected the ribbon cable and got a verticle line of snow instead of a blank line. the line is about 34 mm wide and starts 285 mm from the left edge starts on the Blue and goes to the Red pixels. so if they are 1mm wide that would be 34 bands of color.
I would sure like to figure out the solution to this one or I got a TV I need to throw away cause the o'lady is gonna bust my balls if I can't fix this!
