Seems a lot of issues with that machine
https://www.justanswer.com/electronics/9eecv-master-password-working-vingcard-2800.html
Reset
https://slashersoftware.wordpress.com/2018/05/14/vingcard-2800-troubleshooting/
Information and Videos
https://www.google.com/search?safe=off&rlz=1C1QJDB_enCA643CA644&sxsrf=ALeKk02vO9HfOT9-7ylEfgbVlYGugdUVuA%3A1607447671843&ei=d7TPX8D8MsuZ_QbapqDQAw&q=vingcard+2800+hard+reset
SOURCE: to create a miniproject for hotel management in c++
All Depends on your requirement. First you have choose your programming language, then complexity of project. if you for .Net then you have 2 options. If you want to go for Internet Application then go for Asp.Net and if you want to go for Window application then go for C#.Net. But top of all 1) you have to specify your functionality. 2) Create DFD (Data Flow Diagram) 3) ERD (entitiy relationship diagram) 4) create database.
SOURCE: Lg hotel tv. t.v. button are locked out, only hotel remote works
Hold down the MENU button on the remote for approx 5 seconds. Then enter 1105 this will access the hidden hotel option on the LG tv so you can change whatever you like..
Cheers LITTLE DISH FITTER
SOURCE: Akai TV - Stuck in Hotel Mode
M (menu) 7935 (regular menu appears), them press
4725 (menu service appears), then search HTLSRC (position 090), then
set value 032 (this value disables Hotel Mode) - TV. Now Hotel Mode is
deactivated. It is verified!
M 7935 4725, go to HTLSRC (090), fix 032 - press TV. Good luck!
SOURCE: X Box 360 can't connect in hotel room!
I figured it out! I am also in a hotel room with only ethernet...and can connect to the network but not to the internet. When I got onto the internet for the first time on my laptop, there was a hotel internet webpage that came up immediately. You have to click CONNECT for 24hrs; 48; 1 week etc. unfortunately for us, Xbox doesn't have a internet browser like the PS3 does. So we can not click CONNECT when we are attempting to connect on the 360. The only reason why I know this is correct is because my friend brought his PS3 to my hotel room and that hotel connect window popped up and immediately we were playing Modern Warfare 2 with "full bars"...Xbox should really add a download for a browser! Like 360 way more. Sorry guys!
SOURCE: 32lc5dc lg tv stuck in hotel mode
it is quite possible, if you bought this set from a hotel liquidation, it might still have it's lodgenet card. If it does, then it may be stuck on the channels the hotel had lined up. If there is a lodgenet card (where the cable jack is on the back) you can remove the 2 screws and just pull the card out an inch (leaving it attached to the black cable). Once that card is out, the tv should fall back to normal use. You might need to do a facotry reset to unlock TV options at that point. Only way around this would be to remove the 2 screws holding in the lodgenet card, and pulling it out of the back of the set (Don't have to pull it out all the way, just enough to disengage the data socket. Once the card is removed, you would need an actual LG remote (not the pay per view remote) and hit menu a bunch of times until it stops flashing menu on and off. Once it stops, you type in on the keypad, "98765" "ENTER". This will take you to an installer menu. Scrolling down to the highest numer there is (Should be one backwards from the "000" you start on" there is "Factory Reset" and you use the right arrow key and set it to "1" and then press enter. The TV will flicker a couple times, and then, all inputs are active.
