Question about Whirlpool 18.9 cu. ft. Top Freezer Refrigerator with UltraEase Water Filtration System
Water is leaking inside the refrigerator and the ice cube aren't freezing completely (cube is a hollow shell of ice)
  • jolaw11
    jolaw11 May 11, 2010
    What temperature is the freezer set to? What is the make, model, and age of the unit? Have you ever cleaned the coils? Put a thermometer inside the unit and measure the temperature.
  • Whirlpool Master
  • 909 Answers
Possibly it is because fridge is not cooling correctly(Ice cubes hollow).. Suggest proper defrost. if it is cooling partially, it shows cooling is trying to take place (Make sure before you switch on after defrost, check for proper water drainage.Water must flow to the compressor once defrosted.Take note if the fan runs correctly.
Posted on Sep 20, 2009
6ya staff
SOURCE:
Ice cubes are hollow shells
Check around the hot gas valve for leaks/oil.
Aug 03, 2010 | Scotsman DCE33PA1BC 15in Built-in...
Ice is dumped before totally frozen.
Sounds like a water valve problem. The hollow ice cubes are the giveaway. This means not enough water. only things it can be is the ice maker is not turning on the water valve long enough or the water valve is restricted or the water valve has been leaking and has frozen the fill tube. and is only leting out a small amount of water in this case as well you will still need a new water valve.
start with water valve and if that does not solve the problem you will need to replace the ice maker.
Jan 12, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
My GE Profile refrig ice maker makes hollow ice cubes. Why would this happen?
Not enough water is being pumped into the icemaker. The water pressure in the water line coming into the refrigerator may be too low, perhaps due to a blockage somewhere.
Move the refrigerator enough to get behind it. Turn off the water at the small valve which connects the water line from the house plumbing to the tube going into the refrigerator. Get a bucket. Remove the refrigerator water line from the on-off valve (there should be a compresson nut holding it on). Point the incoming water line into the bucket and open the valve. Do you have a good flow of water? If so, either there is a blockage in the tubing within the refrigerator or the water valve at the bottom of the back of the refrigerator is malfunctioning.
Oct 12, 2009 | KitchenAid Superba Architect KSCS25INSS...
Kenmore icemaker
It sounds like the icemaker is making hollow cubes , and the unfrozen water in the cubes , after dumping , freezes and causes the ice shells to stick togather . This is a sign of " not enough water going into the icemaker " . Replace the water inlet valve , behind the refrig , the piece the wall water line connects to , on the refrig .
Oct 06, 2009 | Kenmore 57029 Side by Side Refrigerator
Ice cubes not freezing completely before dumping
check evaporator fan if working or u may have a leak , or check condsr fan motor :)
Aug 28, 2009 | Amana ARS2464B Side by Side Refrigerator
Maytag msd2356ae ice maker will only give me hollow ice any ideas.
Hollow ice cubes are most often cause by insufficient water supply. Icemakers fill for about 7.5 seconds, resulting in about 4.75 oz. (140 cc) of water into the ice cube mold. If there s not enough water pressure available at the fridge, cubes may end up hollow and/or the fill could continue to dribble, eventually causing the fill tube to freeze closed.
pls rate my suggestion.........
Jul 25, 2009 | Maytag MSD2454G Side by Side Refrigerator
I have hollow icecubes too, and water from the un frozen icecubes spills in bin and all the other cubes stick together. IS There Not a way to adjust the timer on the icemake to turn slower so they will...
your hollow cubes tells me your ice-mkr is not receiving enough water. first check water supply. does your refrig. have a water filter? also you could have a bad/restricted water valve.
Jul 13, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice maker makes hollow ice cubs or cubes with
Whats happening is the ice isnt freezing all the way. Try cleaning your condensor's under the frig.In Hotter weather when condensor's get filled with dust it causes the frig to cycle to ofeten. In turn your cubes aren't freezing all the way.
Jun 26, 2009 | Whirlpool Refrigerators
Ice maker making hollow cubes
check your incoming water pressure, change the water filter recently? hollow ice cubes is a sign of low water pressure
Mar 05, 2008 | Refrigerators
Refrigerators Logo
113 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Bruce Denton
jdthefixer
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
