Question about Photography
Like this, but OOS
https://www.amazon.com/Replacement-Stand-HP-digital-df1010v1/dp/B00DWORWE8?tag=y2iukamdw-20
How about a Plate Stand? Lots of types!
https://www.google.com/search?q=plate+stand
Posted on Dec 07, 2020
SOURCE: Need PANDIGITAL PanDigital 8.0" Digital Photo Frame Instructions.
How about this one:
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4298094&Sku=P32-1044
Posted on Dec 23, 2008
SOURCE: Pandigital frame -how do I extend the stand?
Pull the stand out about an inch, and then SLIDE it downwards, opening it up to make it longer. Be gentle- it works!
Posted on Dec 27, 2008
SOURCE: the Pandigital LCD Photo Frame's "frame extender" won't extend
Just pull it.... straight down. Too much torque may break it.
Posted on Dec 28, 2008
I don't like pasting information, but this is the link to the manual.
http://akamaipix.crutchfield.com/Manuals/692/692PAN902B.PDF
Don't forget to rate my solution, and thanks for coming to FixYa.
Rob
Posted on Feb 21, 2009
SOURCE: Pandigital Photo Frame - Slideshow leaves out Photos?
Size limit depends on exact model. Anything over 4GB will almost certainly not work consistently with any. model 1GB or less should work with any model. None of the images should be stored in folders, and all should be jpeg format (.jpg). If any of them have been edited, they may be saved as Progressive jpeg or something similar even if the extension (.jpg) remains the same. If you resave the missing photos in as JPEG in MS Paint, it should ensure they are compatible. You may have to format the memory card and re-add the photos to make sure it will work,
Posted on Sep 25, 2009
Kick Stand ? - Try a motorcycle spares dealer.
