Question about Power Computers & Internet
Victrola VTA-200b does not work at all like no power to unit . Tried several different outlets with same results. It did work when first purchased. They victrola, called it a dead unit.
Posted by jon McMillan on
  • Anonymous Dec 06, 2020
    it is not a computer, why post here,?
    all things work new and all things fail sooner or later.
    IT IS Radio record cassette play for home.
    it retro, type.
    and is dead, it needs service, it runs on 120vdc, direct to if it is dead the power supply inside is dead or fuse related blown.
    post here to radio not PC
    https://www.fixya.com/troubleshoot/brows...
base mehdi
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 5 Answers
Here's an example of the digital scale I was talking about:
https://www.amazon.com/Image-Digital-Tu ... B00BSP498K. There are clones all over the place. I think they even sell them at Needle Doctor.
Posted on Dec 06, 2020
My portable victrola record player isn't working i've already bought a new power cord and have tried using multiple outlets around my house and it just doesnt power on help please!!! : /
It may have power supply issues, if you have a multimeter pull it apart if you feel ok doing that and test the various components in the power supply section
Need a schematic for a victrola radio model vta 750
The fashion for nostalgia radio with a modern sound has brought about a clutch of models from only a few manufacturers.
I have only encountered one such that was basically an in-house cabinet with bought in internals, the quality of which was probably reflected in the price and as this was from the lower price bracket the internals were from different sources and badly matched.
I know of no reason to assume other models would be substantially different because although popular they haven't sold in the high numbers that would justify purpose built internals and so the chances are an experienced audio engineer would probably recognise the circuit board as being from a popular hi-fi and be able to provide you with details.
Boston Acoustics Recepter Radio HD stopped working - no power. The power supply is fine. is there a fuse in the radio?
There should be a fuse in the back but it would only blow if the wiring is funny because the car's fuses are closer to the power supply and should go first, but try anyway
I have the ultraslim combo ac/dc charger. On the plane, using a standard plug through the power brick, there was no power to the laptop. I tried several different seats with the same result, while other...
The plane may have been running 400 Hz. power through the outlet, and your charger's input filter was blocking it so you didn't have enough voltage getting through. The other passengers probably did not have as much inductance (high-frequency filtering) in their stuff.
I just received the crosley keepsake usb turntable and after plugging in the unit and turning it on I found that it was receiving no power. I tried several different outlets and even tried a different ac...
If you just received it? I would return it. You have done everything i would have done. If its brandnew? I would deffinately return it. You don't want to void warranty.
The green start time is not functioning? I've tried several different green timers and nothing seems to work. Any suggestions?
You posted under Intermatic-malibu power packs
I test timers, I'm not 100% certain what a green timer is.
If you have tried several different green timers, and each has not performed correctly, I suspect electric circuit has interference.
Buy cheap circuit analyzer at home center, and test outlet.
Mover timer to another outlet, on different circuit breaker, and see if problem persists.
For more information on Intermatic/Malibu power packs showing troubleshoot steps, replacement trippers, useful links, warranties and tips:
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
2answers
Unit shuts off automatically after power on.
You have an internal short in the electrical line. your wall a/c [120 volts] goes inside and is converted [changed] to DC [ like a super battery] There are a lot of connections coming out of this POWER SUPPLY[super battery] to FEED other electrical circuit. ANY one of the circuits can demand more then power supply can give and will cause it to SHUT DOWN [turn off to protect itself]
unless u know what u are doing [" DANGER!! wILL rOBINSON, DANGER!!] you should not mess with it.
Open Questions:
Computers & Internet Logo
Top Power Computers & Internet Experts
EKASYS IT SERVICES
EKASYS IT SERVICES
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Power Computer and Internet Expert? Answer questions, earn points and help others
