Do a factory fresh install
the factory is closed
there is NO XP now, zero.
XP is dead, forget XP
MICROSOFT did and so did every PC OEM seller
. END THIS NOW.
I am still using XP on a laptop running old programs that Windows 10 has many issues processing!
Not everything New is better! If it ain’t broke don't replace it, XP is a good operating system for certain programs, Google it........
Obsolete Operating System software! Time for an upgrade.
Press Ctrl + Alt + Delete twice to load the user login panel. Press OK to attempt to log in without a username or password. If that doesn't work, try typing Administrator into the Username field and pressing OK. If you're able to log in, head straight to Control Panel > User Account > Change Account.Dec 21, 2018
5 Tips to Reset the Administrator Password in Windows XP
SOURCE: bypass administration password or reset.
i need to bypass my admin. password. this is for a problem i am trying to fix after windows system 32 config.files been corrupted.
SOURCE: FORGOT MY PASSWORD?
There are a lot of Windows password revealers and crackers available, but I’ve found that Windows Password Recovery Tool is the
most effective.:
it not only supports XP, 2000, and NT, I have personally tested it with Vista Home Premium and Ultimate. It works perfectly to
reset any local user account to a blank password
You can use the ISO to burn a boot CD. Follow these instructions:
1. Download ISO file from http://www.windowspasswordsrecovery.com Windows Password Recovery Tool
2. Burn to a CD using a CD burning tool such as Nero or Roxio or MagicISO
3. Insert CD into drive and reboot.
4. You may have to select an option in the BIOS to get the computer to boot from the CD.
Booting up and clearing a password takes a minute or two works like a charm.
SOURCE: i forgot windows xp admin password
Try your best to recall your windows password, or you have to reset it or reinstall your computer. I do not recommend you to reinstall the OS, which may lead a data loss. So if you really can not remember the password, try following steps:
1. Login to a computer that can link to Internet. Download Windows Password Unlocker 4.0 and decompress it on that PC. Note that: there is a .ISO file. Burn the .ISO file to a CD.
2 Get out the newly created CD and insert it to the locked computer.
3 re-booted the locked computer and then followed the process of instructions. Just a few steps, the old password was removed.'''
4 Setting new password:
Step one: Open the "Control Panel"
Step two: Click the "User Account "
Step three: Select the account you wanna to set a new password.
Step four: Click "changing Account " and "set up password", then fill out the form as listed. Click "Create Password".
SOURCE: i forgot the bios password
The simplest way to remove a BIOS password is to simply remove the CMOS battery. A computer will remember its settings and keep the time even when it is turned off and unplugged because these parts are powered by small battery inside the computer called a CMOS battery. If we pull out this battery, the computer will forget alot of its hardware settings, including its BIOS password. This should not be performed on Laptops if you are not experienced working with laptop hardware.
Anyway, open up the computer case using a screw driver and locate the flat, circular and metallic CMOS battery. It should look something like the picture to the right. Some computers have this part standing upright.
Once you have located it, observe how the latches are holding it. There are many different ways to remove a CMOS battery but the most common way on newer computers can be seen in the picture below.
Make sure to power down the computer, unplug the power cables and unplug any USB devices if they are powered. The computer must not be able to get power from anywhere for this to work. Take out the CMOS battery and wait 10 – 25 minutes before putting it back in. The reason for this wait is because the computer can still store power in its capacitors even though everything is unplugged. The waiting period allows enough time for them to discharge.
Plug everything back in, power up the computer and enter the BIOS again. If everything went well there should be no more password. In some cases, if you get weird error messages during bootup now, you will need to goto “Load BIOS Defaults” in BIOS and save the changes to fix them.
And Thanks.
With AnyPasskey Windows Password Recovery, you can:
the last person on earth with XP the super virus magnet OS. 19 years old OS wow !!!!!
this happens to be easy on XP
and is why it hacks so easy, and infects.
ever use google ?
google XP login password hacks.
3 million hits, must be my lucky day no?
https://lmgtfy.app/?q=how+to+hack+XP+log...
no pC told at all did you ask them
they will tell you sorry no XP support.
it ENDED
April 21, 2008; 12 years ago
are you in 12 year time warp?
the PW is lost
you can guess or hack
google it , 3millions hits, can you not just learn to google , be brave PC will not melt.
xp hacks are easy , too easy..
