SOURCE: dayton unit heater
Dayton heaters are a product sold by Grainger. Contact them for a manual.
SOURCE: Can the Dayton model 3e368e be converted to use
If you know a dealer or repair company,they can order orifices to change out in the unit.
SOURCE: I've got a Dayton 3E369 Unit heater. The electric
Sounds like it has a bad fan switch wich is no more than a small circular bi-metal switch that expands when heated closing a switch. Get a parts breakdown off the net. I am sure you could find the switch in your area and replace it yourself.
SOURCE: Have a Dayton Model 3e228D heater. Problem, unit
The fan switch on this unit is a bi-metal switch located on the heat exchanger. Check for a bad connection. It is 120 volts so be careful when checking. you can test the switch with an volt meter or one of those probe lights to see if the switch closes when hot. you are looking for 120 volts to the blower motor. Spin the blower motor to see if that is bound up with debris.
