Any reset button or what to check
SOURCE: refridge stopped working after a power surge
First, check to see if the light comes on or if there is any fan, motor, or other sound coming from the appliance? If so, the refrigerator isn't really completely stopped--go to the specific problem you are having. If not, try adjusting the thermostat to a colder setting. If that doesn't work, read on.
Second, check to see if there is power getting to the refrigerator. To do that, plug a lamp or other device into the same outlet the refrigerator is plugged into. If there's no power, check the fuses or circuit breakers. If the fuses or breakers aren't the problem, contact a qualified electrician to restore power to the outlet.
If there is power to the appliance but it still seems to be stopped, there may be a problem in one or more of these:
Posted on Apr 03, 2009
SOURCE: Ice & water control buttons
sound like a bad(shorted) dispenser user interface INTERFACE DISP ASM WR55X10415
Posted on Apr 05, 2008
SOURCE: Wont start, power to all parts, is there a reset button?
There is a wiring diagram on the access panel on the back, or in the control head.
Follow the path from incoming power through all switches and leading to the timer.
I suspect either the door switch or start switch has failed.
Posted on Jan 27, 2009
SOURCE: Printer won't turn on.
Please follow the instructions given below to troubleshoot the power issue:
1. Connect the printer directly to the power outlet. Surge protectors can actually draw power away from the printer. If this fails, please try multiple power outlets to ensure your specific outlet is not damaged, and make sure the printer is not connected to the PC while testing the unit.
2. When trying to power on the printer, feel the power supply box (if there is one) and note whether or not it is warm. If it is warm, the problem is not in your power supply, but most likely in your printer. If it is cold, the power supply might be defective.
3. Ensure you have the correct power supply connected to the printer.
4. If you have access to a voltmeter, please ensure that the power supply is giving out the correct amount of voltage (most of our printers use 30 volts output).
Posted on May 03, 2009
SOURCE: sta-rite lp heater wont start
Its the top. There is a membrane that controls the circuit board....the button pad is bad
Posted on Aug 30, 2009
Testimonial: "Thanks, I agree. After checking power supply all the way through to control board, placing a jumper from pins 9/8 and 9/7 on J6 I get lights on LED's"
Jun 27, 2016 | Daewoo Freezers
Sep 11, 2011 | Kenmore Dishwashers
Oct 12, 2010 | Maytag MSD2650K
Aug 16, 2010 | HP Officejet 5610 All-In-One InkJet...
Aug 09, 2010 | Kenmore 77719 Side by Side Bottom Freezer...
May 24, 2010 | Samsung RS2530BSH (25 cu ft) Side by Side...
Feb 12, 2010 | Daewoo F227B Monitor
Feb 20, 2009 | Frigidaire FRS23KF7AB Side by Side...
May 18, 2007 | Daewoo DVG-9200N DVD Player
Feb 25, 2020 | Daewoo Refrigerators
18 people viewed this question
