Question about Whirlpool Washing Machines
Whirlpool cabrio top load washer Have replaced the shift actuator and the shaft pulley It will agitate but not spin. The machine will stop at the spin cycle with lid lock flashing. The control board looks ok and connections are all good. What else could it be?
Posted by Stacy on
Tom Chichester
    Top Expert:
  • Whirlpool Master
  • 62,199 Answers
The control board may have sensed a lid lock failure even if the lid lock is OK.
Posted on Dec 03, 2020
My top load Cabrio won't lock. Innitially it clicks on and then clicks off right away
Typical sequence: power on, lid locks, then unlocks, then locks again and should stay locked the 2nd time. If not, depending on model and design, actuator may need replacing that shifts transmission from agitate to spin.
1helpful
My top load whirlpool cabrio washer won’t start the was cycle. The lid locks, it’s in sensing mode, but not much past hat happens. I can hear a click or two, and the drum will spin around a quarter turn...
Sounds to me like you have a bad shift actuator. It is a small round plastic motor that allows the washer to shift from agitate to spin. Really easy to change out. Find your service manual which is located in a plastic bag behind the front panel up near the top. Inside of this it will tell you how to get into diagnostic mode and pull up error codes. Most F7 error codes will be solved by replacing the actuator. Follow the manual to run it through calibration mode after replacing the part.
Whirlpool cabrio washwer wtw5600xw0 washes fine but when it's time to drain ,it drain's some of the water and it stops i had the pump checked and thought it was bad but it was not , i had a local repair...
So when you say it's not pumping all water out, is there still water standing in tub or no water standing and clothes are just sopping wet? Is machine spinning? If not spinning, could be actuator that shifts transmission from agitate to spin.
8helpful
3answers
Whirlpool Cabrio WTW6600SBT Top Load Washer won't aggitate
My Whirlpool WTW6600 had the same problem. The tub no longer floated up and down on the center shaft, so it only spun, not agitated. You must remove the tub (with some effort) and lightly sand / clean the center shaft. Lube it lightly with wheel bearing grease so that after it is reassembled, you can pull the tub upward and feel about 1/2" movement. This will enable the proper gear assembly to engage. It can spin when it rests at the bottom of its travel, but once you fill the tub, it floats, moving upward, and engaging the agitation gear. Good Luck!
1helpful
How to take a whirlpool clothes washer agitator out of the washer to be replace
  • Pull the liquid softener dispenser off the top of the agitator. Pull the clear plastic cap out of the center of the agitator. Use a ratchet and socket set to remove the hex head bolt from the center of the agitator. Lift the top half of the agitator out of the washer. Pull the bottom half of the agitator straight up to remove it from the drive motor shaft, and remove the bottom half of the agitator from the Cabrio washer.
  • 0helpful
    Agitator stops while in spin cycle
    Assuming that this is a basic Whirlpool top load, direct drive, neutral drain washer, the agitator is supposed to stop during the spin cycle.
    Please see the following Whirlpool installation and service manual for top load machines.
    If you look at the description of how the transmission works, there is an "Agitate Cam" that lifts the "Agitate Gear" out of contact with the main "Agitate Rack" when the machine goes into spin mode
    https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
    I have found though that because of the friction between the agitate gear and main drive shaft, including the oil itself, the agitator may move while in spin mode.
    1helpful
    Agitator seems loose and agitates during the spin cycle
    HI, the actuator shift device in the transmission is malfunctioning. you will need to replace the transmission soon.
    1helpful
    2answers
    Washer won't spin or agitate
    It doesn't agitate If your washer doesn't agitate, check these:
    Lid switch
    Motor coupler
    Belts
    Clutch
    Drive motor
    Drive pulleys
    Transmission
    Agitator
    Lid switch If the lid switch is defective, the washing machine may not agitate or function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
    Motor coupler Many washers produced by Whirlpool® use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. If this happens, you need to completely replace it.
    Belts Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
    Clutch If your washer was made by GE®, it may use a clutch for agitating the clothes. As the clutch wears out, it may prevent the washer from agitating well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
    Drive motor Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
    Drive pulleys The motor or transmission drive pulley may be worn and unable to turn the drive belt. If so, replace the pulley.
    Transmission The transmission could have either of these problems:
    • Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may not agitate properly or at all.
    • The transmission may have a worn or broken gear, or some other internal problem.
    If you suspect a transmission problem, you may have to call a qualified appliance repair technician to repair it.
    Agitator The inside of the agitator--where the transmission shaft attaches--can become worn, and strip out the spline that allows the agitator to properly grip the shaft. Then the transmission shaft rotates back and forth as it should, but the agitator doesn't move properly. If this happens, you may need to replace the agitator and/or the transmission spline.
    It's noisy Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
    Washing Machine Shaft Wont Move
    Lid switch
    Motor coupler
    Belts
    Clutch
    Drive motor
    Drive pulleys
    Transmission
    Agitator
    Washing Machines Logo
    Dan Webster
    Dan Webster
    Gerry Harvey
    Gerry Harvey
    Oloyede Monsuru
