Question about Mitsubishi Televison & Video
I have a Mitsubishi ws55711 tv the timer light has been flashing we haven’t used it in like 3 years won’t turn on, I replaced the capacitors and still no power to the tv just a continuous blinking green timer. Unplugged the keyboard controlling the buttons and still nothing. Help menu and power nothing. What else can I do. Also my remote stopped working I guess as well.
Posted by Mathia on
Larry
  • Mitsubishi Master
  • 3,587 Answers
Check the power supply voltages, if good look towards a bad main
Posted on Oct 19, 2021
5 Related Answers
Anonymous
  • 1153 Answers
SOURCE: Blinking Green Light on Mitsubishi DLP 52525
No problem, do self diagnosis test, read threads here or goto ctechnicians.com get error codes first and get back with me.
Posted on Dec 17, 2007
Anonymous
  • 301 Answers
the dlp will most likely need a qualified mits repair center to take over for you. repairing that set is pretty involved. and the parts you would need are not available to the public.
on your 48" CRT projection check the DM module for 4 vented 1000mf 16v capacitors. replacement should get you tv working great
Posted on Feb 20, 2008
Slinteriors
Sonny Berry
  • 8617 Answers
SOURCE: green power light will not stop flashing and tv will not turn on or off
You need to replace the 1000uf capacitors on the DM board thats the classic symptom of the DM caps being bad the light continues to blink repeatedly. If you need more info on the repair let me know.
Posted on May 16, 2008
Anonymous
  • 928 Answers
SOURCE: Mitsubishi TV Model #ws65869 Blinking Green light
Sorry for the late reply I just got up.
From what I understand of your problem it is most likely a blown capacitor or main IC. Unless I can open up the unit and test the IC's and capacitors I can not be really sure which is why I hardly answer questions about TV''s as they are hard to troubleshoot without the unit in front of you. Ive found a site that can help you via a service manual since I could not find the exact service manual for you from my manual book. The site also has the parts that you will need if ever im right and it is the capacitor or IC. As for the IC's by experience is hard to test without an Oscope but you can do it by gradually eliminating the problem, again you will have to refer to the service manual regarding that. By the way the capacitors I mean is the one that goes to the main module as that is what powers the controls for the TV. the green light is just the "pilot light" which means you have power to the TV but the power is not going past the capacitors to the main controls or the main IC. So simply put the problem can be the capacitors (Which is what you check first) if they are ok then look at the IC via using a service manual. You can use a multitester for the capacitor first if they are dead then just change them and you should be ok. Let me know what happens or updates ill reply to them as well.
Posted on Sep 02, 2008
Anonymous
  • 9 Answers
SOURCE: mitsubishi hdtv1080 won't turn on. green timer light flashing
could be a lot of things really. when you replace the bulb, there is a switch that will prevent the tv from turning on if the cover isn't sitting correctly, by moving it that might have shifted so it would blink, but not turn on. if not, well get it serviced, sorry
Posted on Mar 18, 2009
Flashing timer light on a mitsubishi wd-57733
Good day!!!!
That problem is usually cause of faulty capacitors on the power supply board..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter
1helpful
2answers
Green timer light won't stop flashing on mitsubishi ws 73711.
the green light blinking is normal if set has been unplugged--when set is plugged back it should blink for about 70 seconds and then go out--then you can try to turn it on---it is the DM unit inside the set booting up.
If the light just blinks and never stops you have likely bad caps in the DM unit---there are kits available for that.
The other possible reason is that so called reset switch may be bad--fairly easy way to find that out and it is more common than you would think, let me know if you have questions.
SD TECH
2helpful
Timer light will not stop flashing. can't turn on TV
Unfortunately the first generation DLP's from Mitsubishi are prone to have Capacitor failure through out the chassis. Most likely that is what your set is experiencing. I would start by replaceing the suspect caps on the DM amd The Power boards. You can get the V26 Chassis DM/Power repair kit from www.tvrepairworld.com which also contains instructions.
Mitsubishi TV green flashing timer light after power outage.
You will need to cahnge the capacitors on the DM board, very common problem. The V21 V19 DM repair kit at the following link contains the replacement capacitors and detailed instructions. Its listed under the repair kits catagory at the following link.
http://servicemanuals.vstore.ca/
2answers
I turned on the TV but just got a black screen but could hear audio just fine. Turned the set off and unplugged it. When I plugged it back in the green timer light started flashing and would not stop...
Nonstop blinking is likely a DM or format board - format board most likely. I have rebuilt several of these by simply replacing all the caps, about 70 of them, and takes about two hours start to finish... But this set does need to boot. It takes about 70 seconds of flashing green light before you're able to press the power button - even when everthing is working as it should..
Hope this helps!
Bill
William Rayburn, CET
Premium Technologies
PO Box 442
Long Beach, WA. 98631
360-642-4993
1helpful
Timer light flashes tv won`t turn on. mitsubishi model #55859
You have a bad DM board - the capacitors are bad and need to be replaced. I was able to replace them myself. There are no replacement parts available and many repairmen will charge hundreds of dollars and there is no guarantee they will fix it.
1helpful
2answers
Timer light did not stop flash
Lamp is not the issue. It most likely is a your DM card. You most likely have some capacitors that need to be replaced. This is a terrible issue with this unit. Do a google search for "DM" and the model number and you should see hundreds of posts.
2answers
Mitsubishi 52" WD52725 flashing green timer light
your projector bulb went out. you need to call the manufacturer and order a new bulb. they cost 300 to 400 dollars a piece I believe your tv only has one bulb and they are really easy to install.
hope this helped
please rate well.
If you need further help, reach me via phone at https://www.6ya.com/expert/mark_445a24324be9eb03
4helpful
Mitsubishi hdtv1080 won't turn on. green timer light flashing
Televison & Video Logo
Top Mitsubishi Televison & Video Experts
Ekse
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
